Hayward Viper Pool Cleaner Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please provide instructions for replacing worn wear rollers on the hayward viper sweeper hose. Removing the worn ones is easy enough, but placing new ones doesn't seem possible unless you're able to dismantle sweeper hose parts.
Anonymous
Level 3:
  • Master 990 Answers
  • Posted on Dec 07, 2009
Anonymous
Master
Level 3:
Answers
990
Questions
Helped
468945
Points
2217
If you look closley you will see that the end piece of the hose is a plug that slides into a coller. The outside will slide back and the end plug or nozzel will come out of host at that point. Good luck.
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 • Dryers
Describe your DBSR453EBWW / DBSR453EBCC Electric Dryer Problem Dryer makes a loud noise and gets really hot fast even on " less dry" and smells electical afraid to use it, heating element or...
Hi bbunnymc...
2 possible problems with your dryer...
1...Drum roller noisy making the loud noise you hear.
2...Vent system of dryer plugged up with lint,socks,pens,etc.
I will give solutions to both below
-----------------------------------------------------------------------------------------------------------------------------------------------Problem 1 solution...ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers are in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
2...Problem solution...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Note: You can get to the most of the vent system thru the removal of the back of the dryer
Please take time to rate me.
My viper just started spinning in a continuous circle wrapping the hose completely around the cleaner and the bag. It's not a hose problem. It was working OK one day and started this the next.
That sounds wild. I would call the Hayward technical service number at 908-355-7995 and maybe they can figure this out. I hope this helps.
Please vote for this answer. Thank you.
1helpful
Sweeper does not reach end of pool
Check your returns. They may be getting a flo going in the pool that keeps the cleaner from getting to one end. Usually this is due to the current pushing the floating hose around pool. To fix this simply aim the returns down into the pool rather up on the surface. It sounds like you have enough hose. I hope this helps you good luck.
Belt tensioner overheated and doesn't keep belt tight enough
Looking at the owner manual, there is no tensioner assembly.
If the motor is fixed in place and not loose, then you either have the wrong belt, or the brush roller is not properly installed, or the brush roller is worn out where the belt goes around the brush roller.
Roller does not turn; I was vacuuming a rug and a string got stuck in roller-took it off but now the roller will not turn. suction is fine.
The roller drive belt may be stripped, worn partway through where it goes around the motor shaft, thrown off the motor shaft, or broken. Take the bottom plate off the carpet sweeper and have a look.
If the belt was damaged when the roller brush got stuck, then you get to replace it. On most of these, the easiest way is to put the new belt around the roller pulley, reinstall the roller, stretch the belt around the end of the motor shaft, then turn the motor by hand while pushing the belt on. If the motor also has a pulley on it, you may have to remove the motor screws to get enough slack on the belt, then pull the motor into place and put the screws back in.
5helpful
Water is coming out of backwash hose while in filter mode?
The gasket inside the valve is likely rolled out of place allowing water out of the backwash port. It may be salvagable if you reseat it. Otherwise it will need to be replaced.
11helpful
3answers
Hayward Viper 5500 is spinning in circles
We found the problem to be a faulty check valve. the check valve cost about 25.00. I ordered it from poolcenter.com. The check valve is located by the cam. It's an easy fix. The check valve comes with the hose attachment, but since our hose was ok we just used a tie strap to connect the new check valve to the hose...sliped back into place... and it works like a charm once again. The part number is below. go to www.poolcenter.com
HAYWARD VIPER CHECK VALVE W/ HOSE & TIES - AX5000CVA
2helpful
2answers
Pickup Roller wear
I have had the same paper jam nightmare as many CLP-300 users and just as I was on the verge of throwing it away I appear to have solved the problem. The paper tray has adjustable plastic guides on either side. I loosened them slightly to allow an spare eighth of an inch each side and I've had no problems since. I can't believe the problem that plagued me for months was so easy to fix.
3answers
Eureka Central Vac-Sweeper -Model B1501
I like using a Wire Clothes hanger to work the stuff out with. If you fashion a fish hook of sorts out of the wire, you can catch things inside the brush head and pull them out.
Oct 24, 2007 • Vacuums
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
