Question about Dell 924 All-in-One InkJet Printer
Faxing on my Dell Pc
I use Windows XP with AOL 9.1 and my printer is Dell All-in-one 924. I have used the fax many times before, but now I get a pop-up saying"the fax printer cannot be accessed. make sure it is setup properly". I hve tried everything, but cannot fit it. Can you help.
  • 1 more comment
  • smitty1935 Jan 02, 2008
    I did the System Restore task and still have the problem. I don't know how to reinstall the driver - can you give me instructions. Thanks
    I don't know how to update or reinstall drivers. Can you give instructions....
    The only thing that might have caused this problem is that I installed "My Camera" to get pictures from my digital camera.
  • smitty1935 Jan 03, 2008
    Please advise how to remove and install drivers...thanks
  • 689 Answers
Probably related service has stopped or configuration has been changed. There are 2 method that you can try. First you can reinstall the driver and the applications that came with CD
Second Solution is using system restore.
To perform system restore you need to go to Start Menu > All Programs > Accessories > System Restore.
On System Restore task set to computer earlier date that you remember most recent time that printer was working fine. Perform the system restore and Test the result.
If issue persists please inform
Good Luck
Posted on Jan 01, 2008
    President:
  • 1,944 Answers
Have you tried turning the printer off and on again/unplugging and repluggin the USB cable at both ends/try another USB port/restarting Windows/update or reinstall drivers. Do you remember if you installed something that could've caused this error?
  • Damen Wong
    Damen Wong Jan 02, 2008
    Try this guided setup from Dell.
  • Damen Wong
    Damen Wong Jan 03, 2008
    - Turn your unit off
    - disconnect it from your PC
    - go to device manager
    - find your device in the list and enter it's properties
    - go to the driver tab
    - then select uninstall
    After this reconnect the printer and reinstall the driver.
  • 490 Answers
Dear Smitty1935
Kindly remove all the drivers and install once again the drivers , please note , do not take option reinstall, remove the drivers and then install the fax drivers
thanks
Gizmo
How to canon lbp 2900 self test page without pc
Make sure the printer turns on/on
  • Press the resume should not be removed
  • Keep press the button until the power lamp lights up resume/flashes twice
  • Then release the resume button
  • Jul 06, 2012 | Canon LASER SHOT LBP-2900 Printer
    How to enable ms fax services
    1. 1
      Open the Start menu and select "Run", then type "appwiz.cpl" into the textbox and press "Enter". This will bring up the "Add/Remove Hardware" dialog box.
    2. 2
      Click the "Add/Remove Windows Components" button in the left portion of the dialog box. It will take several seconds for the list of installed components to compile.
    3. 3
      Click the check box next to the "Fax Services" entry and click "OK". This will start the install process for the Windows XP Fax Service. You will be prompted to insert your Windows XP setup disk at some point in this process. Do so, then press "OK" to continue and complete the installation.
    4. 4
      Click "Finish" to exit the installer program.
    Jan 14, 2011 | Dell 924 All-in-One InkJet Printer
    Can not install dell aio 924 on windows XP
    Fisrt go to Start menu click on printers and faxes and delete your printer. Go to the start menu and click on control panel and then click on add/remove programs remove the printer software If you see it their. Restart your computer.
    go to this Dell site and download the driver
    http://support.dell.com/support/downloads/driverslist.aspx?os=WV64&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&hidos=WLH&hidlang=en&TabIndex=&SystemID=PRN_ALL_A924
    Jan 07, 2010 | Dell 924 All-in-One InkJet Printer
    Dell print font too small
    In the software drivers for the printer you should be able to find a properties page and you can change resolution, font, and color properties.
    On a windows xp computer click start, then printers and fax machines, then right click on your printer, then click properties.
    FIXYA!
    Apr 28, 2009 | Dell 924 All-in-One InkJet Printer
    Setup as fax
    What you need to do to set up fax on most printers is use a standard phone cable. ( Cat 3 )
    Plug one end intor the printer and the other end into a phone jack.
    Then follow the instuctions on the manual to set up the fax number on the all in one printer.
    With this printer you can also fax by using the microsoft software.
    Here is the manual and it has step by step insturctions on how to set up faxing with software.
    http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
    Nov 13, 2008 | Dell 924 All-in-One InkJet Printer
    Long distance faxing
    Check out first with your Telephone services, and then since it take time for fax for a long distance so wait for 10 minute to complete a page.
    Also read the useful information for setting from Dell Website:
    How To send Fax
    Let me know if I can assist you further.
    Regards
    Ellin
    Oct 03, 2008 | Dell 924 All-in-One InkJet Printer
    Dell924 all in one
    got your e-mail asking me to post how i fixed my 924 printer. well you post how you wpuld have fix it then ill post mine
    Using fax
    Please go to the Dell Printer site using this link, where you can get all the useful information:
    Dell Printer How To Fax
    Let me know if you face any difficulty or need any assistance.
    Regards
    Ellin
    Sep 26, 2008 | Dell 924 All-in-One InkJet Printer
    Dell 924 fax
    Hi ,
    The 924 printer which you have is not a standalone faxing printer, in order to send or receive the faxes the printer should be connected to the computer and the phoneline should be connected to the internal modem of the computer and you will be able to send the faxes by scanning the document from the printer, you will find a software called ALL IN ONE CENTER installed on your computer , open the All in one center and then click on FAX Now and you will be able to send a fax.
    Mar 29, 2008 | Dell 924 All-in-One InkJet Printer
    Dell 924 All-in-One InkJet Printer Logo
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
