Question about Fuji FinePix A350 Digital Camera
FUJI E 510
My camera totally locked up with the lens out and the shutter what appears to be half open as it does not totally open to the size of the lens. I have changed batteries several times and played with the setting with zero results.
Any suggestions will be greatly appreciated.
  • ReeRainey Mar 17, 2008
    My camera stopped working for some odd reason. It's stuck with the lens out and no power. I have changed the batteries multiple times and no luck.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Not described in the instruction booklet. Call Fuji support, and arrange for a replacement if it is still in warranty
Posted on Mar 25, 2008
The shutter speeds on my Horizon Perfekt do not change when i adjust the dial.
The shutter speed is controlled by the width of the slit exposing the film. So, the lens will swing at the same speed when set at 1/500 or 1/60 (White setting), therefore it appears on the outside that the shutter speed has not changed. The swing has only 2 speeds, White fast, Yellow slow, selected by the switch on the left beside the rewind knob.
To confirm that the width of the slit is changing (actual shutter speed), open the back and fire the shutter on Yellow 2 (half second), you will see the slit is fully open as the lens swings. Next try Yellow 8, you will see the slit is less than half open, so it exposes the film for a shorter time by having a narrower slit , not faster swing.
This is the same principle in many cameras with curtain shutter.
I hope this answers your question.
Oct 13, 2010 | Horizon Perfekt Film Camera
How do I make my shutter speed faster?
Shutterspeed depends on 3 things: the amount of available light, the aperture (lens opening) and the ISO setting.
Every full step you can open the aperture (like from F8 to F5,6) will half the shutterspeed. And every time you double the ISO, the shutterspeed will half. Raising the ISO will increase the noise in the picture.
Mode P, S, A and M will allow you to make these settings manually. If you use the N mode, the camera will do most of these things by itselves.
May 03, 2010 | Fuji FinePix S1000FD Digital Camera
I often miss a shot because there seems to be a delay when I press the shutter button on my Fuji FinePix A350 digital camera. Is there a setting I can change to speed up the process?
It's called "shutter lag"...a common problem with all point and shoot cameras. To avoid it, press the shutter button half-way and allow the camera to lock in the focus (it will beep) before pressing the rest of the way.
Jan 03, 2010 | Fuji FinePix A350 Digital Camera
Shutter speed on the auto mode of my s1000 camera seems slow. how can it be increased in the auto mode? This is a Fuji camera and by the time I press the shutter button subjects have moved. I have set the...
You need to press the shutter button half-way and allow the camera to lock in the focus before you press the rest of the way. This eliminates "shutter lag".
Dec 30, 2009 | Fuji FinePix S1000FD Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
When I turn on my camera the screen is blank
Do the icons show up on the screen or is it totally blank?
Can you view previous pictures?
If the icons show on the screen then have a look into the lens to see if the shutter is closed over the inner lens. you may have to adjust the zoom to bring the inner lens and shutter mechanism up close to the outer lens to get a better look.
If the shutter is covering the inner lens then it is stuck and will need to be freed by opening the camera up.
If the screen is just black then it just may be possible that the ribbon for the screen has partially slipped out of it's socket on the main board.
If it comes out all the way then the camera should not even power up.
Jul 27, 2009 | Fuji FinePix A800 Digital Camera
Fujifilm camera f470 white lines problem horizontal
your shutter is not closing over the lens completely. try taking video, that should be ok. your lens will have to be stripped down to clean the shutter
Apr 02, 2009 | Fuji FinePix F470 Digital Camera
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
The camera goes on but lens error appears on sscreen and the lens does not protrude out. shutter is half open
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Nov 23, 2008 | Nikon Cameras
Repair Fuji F30 shutter button does not work, case damaged
I also dropped my Fuji F30.
The half-press of the shutter didn't work anymore.
I bought a triwing / triblade screwdriver (about 5 euros) to open the case.
The flatcable running from the knobs on top of the F30 to the main print was a bit loose. After reconnecting it, the shutter button was fully functional again.
It seems that from the backside the most 3 three wires in the flatcable are for the shutter, so if your cable is also a bit loose, this might solve the problem.
NB Remember to only open the backside of the casing, there is no need to open the lens-side. Opening and closing the backside is really easy and could be done by anyone with the right tools. (read screwdrivers...)
Oct 28, 2007 | Fuji FinePix F30 Digital Camera
Fuji FinePix A350 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
