Microsoft Wireless Optical Desktop Comfort Edition
Problem for Microsoft Wireless Optical Desktop Comfort Edition
I had to recently puchase an emachine as I am on
By ssmith956 on Oct 27, 2009
I had to recently puchase an emachine as I am on ss disability. I would not have purchased (I usually buy Dells) It came with a PS2 mouse and keyboard and 10 slots USB slots. The only things that my USB slots find: my printer, my cameras but not my mouse. I tried to get a download from Microsoft and I feel like a hamster running around on a wheel. Getting absolutly no where. I hate the PS2 mouse and keyboard. Can you help?
Comments:
Oct 29, 2009
- I appreciate the tip but tried that it still only found my printer and camera ports. It just doesn't recognize the mouse. The E-machines tech could not help me at all. I did everything I said and then they said I probably needed to get a new mouse but I'm afraid if I do, it won't work either. Thanks for the tip though!
Solution #1
posted on Oct 29, 2009
Not Rated)
bob_computer
Rank: Guru  Microsoft Computer Accessories  Expert
Rating: 87%, 1228 votes
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Was this helpful?
Yes
No
Solution #2
posted on Oct 28, 2009
Not Rated)
Awaji
Rank: Master  Computer Accessories  Expert
Rating: 97%, 3 votes
it is treky when connectting usb devices to a computer!
some usb slots will not work others may work ok.
try to connect your device to all usb slots one by one untill one off them recognize it (hopfulyl)
Was this helpful?
Yes
No
Popular Solutions for Microsoft Wireless Optical
Questions and Unsolved Problems for Microsoft Wireless Optical
Do you recommend Microsoft Wireless Optical Desktop Comfort Edition?
Answer
Answer
I have a microsoft wireless comfort keyboard 1.0a How do I unlock it or remove the numlock
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Wireless Optical...:
Top Keyboard and Mice Experts
Rank: Guru Guru
Solutions: 14896
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Keyboard and Mice Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
