Question about Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck
Cassette Tape stuck
I have a Sony TC-WR645S dual cassette tape deck with a cassette tape stuck in one of the decks (it was trying to REW when it stopped and got stuck). Every time I turn on the deck, it seems to try to FF or REW the tape for a couple of seconds, but nothing happens, and I cannot eject the tape. Is there a way to remove the tape?
  • 7 more comments
  • analog_guy Jan 13, 2008
    Tried that. Unfortunately, the eject button is a manual type of eject -- not electronic. Thanks though.
  • Anonymous Jan 27, 2008
    Have the same problem - the deck gets very little use - I saw on another post to take the cover off and manually unlocking it - I was able to get the tape out, but the deck wants to go into a FF or REW mode and none of the buttons respond - thus causing the tape to get stuck again.
    I last played a tape not more than a month ago and the deck worked perfectly - not sure why it is causing problems on both A and B decks
  • Anonymous Aug 28, 2008
    Same problem. Can't open the compartment where I inserted a tape. It will wind and re-wind, but the door won't open. And the empty compartment won't open either.
  • mchalan May 11, 2010
    follow on to "Guest: post 27 Jan 08. I also with the cover removed cleaned the capstans and belts with a q-tip and alcohol - had some moderate success with the A deck, but none for the B deck. I saw on another posting to replace the belts - any suggestions on where to find replacement belts and how hard are they to replace? Can I do this myself or should I take to the shop? Thanks
  • Sam Palermo
    Sam Palermo Feb 25, 2013
    These are really meant to be throw away items- buying another of the same thing just throws more money down the drain, Learn for the experience of this one and move up to something that is good.
  • Anonymous Mar 28, 2014
    I own a TCS-310, perfectly working except the FF/REW control. The engine seems to get active as it produces the normal "play noise", but nothing is apparrently moving. Any advice?
  • Anonymous Mar 31, 2014
    v-3rx non si chiude il cassette holder
    v-3rx non si chiude il cassette holder con il tape
  • Sony Master
  • 1,267 Answers
Most of these least expensive unit have this problem as the mechanism are not designed like the large solenoid models were that last many years- some 30. The belt that drives the flywheel where the mechanism movement is loose or broken and it is even with a good belt that the mechanism needs lubrication. This would all be taken care of by a repair Technician. I work on units all the time but I don't know if this priced of unit would qualify for repair as repair can cost over $100.
Posted on Feb 25, 2013
It needs new belts. Not easy to do yourself. I have done one and it is very difficult. Must also align gear wheel which will probably go out of alignment while you are trying to replace the belts. Big pain. Cheaper to just buy another used model or better yet a new one.
Posted on Jan 24, 2009
I have a same problem with my Sony TC-WR645S Stereo Cassette Deck. I can not eject the tape.
Please solve this problem for me.
Posted on Sep 30, 2008
How does one take the cover off?
Posted on Feb 02, 2008
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
Posted on Jan 11, 2008
Hookup soney duel tape deck to onkyo equalizer
If you are trying to equalize the sound from one half to the other ... you cannot, unless there are separate INPUT and OUTPUT jacks on the back. Otherwise you will need a second cassette deck.
Sep 23, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC WR565 dual tape deck. Both doors will not
you can not fix it without tearing it apart. if you do take it apart, try to get the front panel off. Hit the eject button and look for a lever that is stuck.
Jun 17, 2010 | Sony TC-WR565RM Single Cassette Deck
Neither of my soni rx88 cassette deck, A or B is
The little brown wheel... Do you mean the rubber idler pulleys that are brown because they've never been cleaned? If they fell off they'll need to be replaced properly by a tech.
Apr 30, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Belt replacement in a sony tc-wr645s tape deck
I have just spent half a day trying to replace the drive belts in my sony twin deck unit , in the end it still didnt work as the the old rubber belt did some damage to the unit , anyway shops like **** smith or tandy stock the drive belts , take the front of the unit away from the main case there will be a plastic casing that surrounds the belts there are at least two belts, there should only be two small screws undo these and move the plastic unit forward on the plastic mounting brackets then you will see the metal wheel and the plastic wheel that you fit the belt around , its a bit fiddly but i can do it in my sleep now even though the motor died it was a good experience
May 21, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Sep 30, 2008 | Audio Players & Recorders
Magnavox tape deck
Jan 20, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck Logo
1,509 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
