Question about IOGear GCS632U 2-port KVM Switch
GCS5632u KVM swith working with Vista
I'm having a problem getting my hotkeys to work. I have one computer with XP, the other with Vista. I'm using a wireless Microsoft keyboard with wirless mouse. It doesn't have the lights on them, so I'm not sure when I'm entering hotkey mode.
Make sure the keyboard/mouse receiver is connected to the keyboard port on the KVM -- there is an embossed icon near each port -- mouse and keyboard.
Posted on Jan 09, 2008
I'm playing a game that uses tab key a lot. The dvd hotkey is right next to the tab and it tries to load that over my game. How can I disable that hotkey. The program came with the computer and I...
Uninstall the hotkey software from Control Panel (Add/Remove Programs in XP, Programs and Features in Vista, 7)
Alternatively install Startup Control Panel and uncheck the program from startup.The program works great in XP, for Vista and 7 there is more playing around:
  • Download the zip file
  • Click Extract All files
  • Right click on the program
  • Choose Run as Administrator
  • Install the program
  • Open Control Panel and choose Classic View
  • Run Startup
  • Uncheck something in HKLM and it will duplicate
  • Close Startup
  • Wait for Windows to pop up a box
  • Click Reinstall using recommended settings
  • Allow the program to run
  • Now you can remove the programs from startup.
  • Restart your computer
Jul 23, 2011 | Computers & Internet
Cannot invoke hotkey function to switch computers .Directions say use num loc key plus minus key and release num loc but this doesnt work.
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, a much better hotkey for this switch is to tap scroll-lock twice. This automatically switches, so you don't have to hit multiple buttons.
Feb 18, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
My computers seem to have become somehow linked by the KVM switch
The GCS632U is just one KVM switch. But if you're going to check it out, it has actually two separate connections.
It will just switch once you toggle from one computer to another.
Try to power cycle the KVM switch.
1. Shut off both computers.
2. Disconnect the KVM switch from the computers. (make sure that not even a single cable is connected to the computer, even the audio).
3. Leave it disconnected for 10 minutes.
4. Reconnect the KVM and boot up the XP first.
5. Boot up the Vista, try to toggle from one computer to another.
6. LASTLY, shut off the Vista and see if same problem will occur.
If you get the same problem, then you need to contact IOGEAR and have them RMA the device. Because this is the first time that I heard of this problem.
Thank you and good luck!
Jan 25, 2010 | IOGear GCS632U 2-port KVM Switch
FN hotkeys Wireless on/off dosent work!!!?????
first configure your wireless router with a ethernet cord on a station pc using the software that router came with ..... it should be a step by step process (self explanatory}once that is done make sure the router is transmitting by trying to log on to a web site
once that is done .......as i will tell all my firends vista isnt for every pc alot of pc or xp based drivers arent compatible on vista , has it ever worked on vista before if yes then try reinstallin the driver for your wirelss card ....good luck
May 06, 2009 | Computers & Internet
I have a kvm switch vista lap and xp desktop stopped working
I've gone through alot of KVM switches. Something in the electronics just gives up. If your keyboard and mouse are the pci type (round connector) then don't switch their locations while the computers are on. Windows won't see the change and you may damage the system. If thy're USB type then switching is OK.
Apr 07, 2009 | Computers & Internet
All Keys do not work on keyboard with KVM switch
GCS632U is designed to work with standard USB keyboard an mouse only. You have to make sure that you are not using any type of adapter such as PS/2 to USB adapter. To further isolate the problem, please follow the steps below:
1. Connect the USB keybord directly to th computer to make sure that the keyboard is working properly.
2. Make sure that the keyboard is connected to the keyboard port on your KVM switch. You may take a look under neath this GCS632U (near the USB ports) and you will see an icon where to connect the keyboar and mouse.
3. If you're still gettings the same problem, Try power cycling this kvm switch by disconnecting if from the computers and disconnect also the keyboard and mouse from the KVM switch and leave them disconnected for a minute or two.
4. Reconnect everything after two minutes and then reboot the two computers.
5. If same problem exist, try using different USB keyboard.
NOTE: This KVM swith does not work correctly with wireless, gaming and smart keyboards because it's designed to work with standrd USB keyboard only.
Mar 23, 2009 | IOGear GCS632U 2-port KVM Switch
Need drivers for xp and vista
Most KVM switches does not have a driver. Because these devices are simply Plug-n-Play and does not require any driver installation.
What you need to do is to check the system requirements for every KVM switches before purchasing it.
Here's the fact:
- PS/2 KVM switches are designed for PS/2 computers keyboard and mouse
- USB KVM switches are designed to work with USB. Meaning, if you're going to use an adapter (PS/2 to USB), there's a big chance that your KVM might not work correctly.
- Most KVM switches does not work properly with docking stations.
- KVM switches are tested to work with wired keyboards and mice.
- You have to make sure that everything is properly connected to the computers if you want your KVM switch function properly.
- Lastly, update the USB driver of your computers (XP and Vista).
- Most KVMs has a firmware upgrade that you may find in manufacturer's Web site.
Mar 08, 2009 | Computers & Internet
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
Direct Access Buttons
the hotkeys are funcion becouse the ps/2 manual operation, but you have to claim the waranty fortunatily the omniview have 5 years in both parts and services claim it...good luck
Aug 10, 2006 | Belkin OmniView PRO2 8-port KVM Switch
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
385 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
