Question about Sony KV-32V26 32" TV
Loss of power
My ~9 yr old Sony KV-32V26 suddenly will not turn on. It acts exactly as if unplugged (although it is plugged in to a verified working outlet). A buddy of mine who used to repair TVs told me to check the fuse on the power board which appeared to be intact. He took a look inside the cabinet and said it looks as if the power board may be bad. How can I go about troubleshooting/repairing the powerboard without getting the entire board replaced?
  • Anonymous Aug 14, 2008
    Yes I have a similar problem. TV just stopped working suddenly - any idea how I can resolve it
  • 579 Answers
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Be careful on buying a new one though. Often times, they are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
But if you really want to repair it - sells the whole main board for about $170
Also might check with Module Exchange at 972-298-1212
Posted on Jan 01, 2008
Our Sony tv is acting up....first it had no sound....then wouldn't change no sound or picture and turns off right after you turn it on?
I feel your sony is going to need another power supply in it or have the power suppply reworked. You might have bad eletrolytic capacitors in it that is causing this issue. That is what it sounds like when you said first the sound did not work then the remote did not work until total failure.
You might want to take that down to the tv repair shop and have them look at the power supply.
thanks and please do leave postive feedback and ratings for your free answer today.
Jun 14, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony KV-32V26 turned off while watching, now I can't turn it on
I have a set I'm working on right now, same model number and symptoms. It is a fairly common problem and the repair consists of replacing 3 transistors, one resistor and one VDR (voltage dependent resistor), along with re-soldering some connections on the main PC board. You'll need a technician to do the work, and it will likely be well over $100 to repair. I would consider replacing the set with a HDTV model if you can afford to. The picture tube may be the next to go.
Apr 02, 2010 | Sony KV-32V26 32" TV
My Sony Wega TV, KF 50WE610, suddenly will not display a picture when we turn it on. We have only multi-colored vertical stripes; however the sound does work. Our carrier is DirecTV. A second TV in the...
Hello there David,
How old is the tv? For the problem like this with the Sony Wega, you can do a power reset. Power off the TV and unplug the power cord from the electrical socket. Wait for like 1 minute, plug it back then turn it on.
If it doesn't work, then your Digital Mirror Device on the tv failed. You can call sony customer service at 1800 222 7669 to verify this hardware problem.
If you need further assistance, please let me know.
Mar 04, 2010 | Computers & Internet
Sony FD Trinitron WEGA KV-32HS500 32" just stays on standby & blinks 7 times give no indication there were any probems.- wont turn on when you push the power button it acts like it is going to come on...
we have the same porblem. We just unplug ours and wait a couple of weeks while watching another tv plug and un plug it will eventually come on then we dont turn it off again it only goes off if the power goes off.
Jun 07, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Trinitron
I am having the same problem my tv will not turn on all of the sudden, standby light flashing, cnnot get it to do anything
Jun 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No Power
Hi: That could be the power cord itself shorting out right near where it plugs into the set.
DO NOT hesitate removing the plug from the AC wall plug, since fires have started this way!!
If its the cord you can replace it or if its inside the set it will need repair.
Mar 13, 2008 | Sony KV-32S66 32" TV
No Power on Sony TV Model KV 36FS120
The sympthon 9 blinks :
Check at G board : D6301 D6116 ( replace with new one !!!! ).Voltage around +/- 12 -13 v .
e-mail :
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
1. Place set on flat solid surface (garage floor or driveway).
2. Bang into it with SUV 3 or 4 times.
3. If set fails to respond, crush against garage wall or drive over it
Jan 13, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony tv kv-36fs120 will not turn on
Use a hair dryer on the back right side of unit. Humidity sensor may be causing the unit to stay off. The hair dryer may also remove dust causing a false humidity detection
Nov 10, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony TV KV-32v26
Do you mean basic CABLE channels or Aerial channels? If aerial, what kind of antenna are you using (you must have SOME sort of antenna... rabbit ears, set-top, etc...)?
Sep 20, 2007 | Sony KV-32V26 32" TV
Televison & Video Logo
179 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
