Question about Samsung RS2630SH Side by Side Refrigerator
Samsung rs21dpsm only a small green dash is iluminated on the control panel,on the door, aftre power failed, the question is, is the main pcb or the display pcb which is the likely to be damaged
  1. only a green dash
  • Anonymous Mar 28, 2014
    GOOD DAY
    I HAVE A SAMSUNG REFRIGERATOR RS21DCNS, IT HAS A LINE ACROSS THE DISPLAY,AND IS NOT DISPLAYING ANYTHING AND IT IS NOT RUNNING, I HAVE REPLACE THE MAIN PCB AND DISPLAY PCB, WITH THE SAME RESULT, ANY THING I MAY TRY.
Press power cool and power freeze buttons together until display lights up
Posted on Jan 03, 2008
Thank you by pressing both buttons it works at last you are a genius and
green milie and mal one thank you
jon
Posted on Jun 24, 2008
Pressing the pwer cool and power freeze worked for me-Thanks !
Posted on Jun 23, 2008
    New Friend:
And 4 years later worked for us as well....thanks very much, and just saved us a lot of dollars just to get a bloke out to fix it....cheers!
Posted on Nov 27, 2012
E000000-0000 solutions in you tube
E000 is a heater temperature fault. (fails to increase)
Try to clear the code in the service mode.
COPIER>FUNCTION>CLEAR>ERR
If that does not work, check the fuser's main thermistor and see if it an open circuit.
Other problems:
Main power supply PCB or DC controller PCB is faulty.
Door switch is faulty.
Aug 11, 2014 | Canon IR 3300 Digital Copier
Samsung tv won't turn on
try the main PCB. This has your CPu on it which controls this circuitry.
Try this web site, but use your COMPLETE model number as various sub models use different parts. https://www.encompassparts.com/model/SMGPN51F4500AFXZA/_/_/Samsung/PN51F4500AFXZA/51-INCH_PLASMA_4500_SERIES_TV_720P
main PCB: BN96-24574A
MAIN PCB BN96-19471A
http://www.samsungparts.com/Products/Parts_and_Accessories/PN51F4500AF/Default.aspx
MAIN PCB: BN94-06195C
Mar 03, 2014 | Televison & Video
I bought my 46" samsung
The Capacitors on the Main Power PCB are failing which is why it's taking 3 attempts for them to charge before the TV will switch on.
These could be replaced for a few $ if you know someone with the technical ability and equipment.
Failing this it would require a new PCB at around $120 + fitting.
Jun 11, 2011 | Samsung LN46A650 46 in. LCD HDTV
How to resolve e00002-0000
E002
The main thermistor (TH1) has poor contact or an open circuit. The thermal
switch has an open circuit (TP1). The fixing heater has an open circuit. The
AC driver PCB is faulty. The DC controller PCB is faulty. The door switch
is faulty.
E002
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause: The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact,
or the fixing heater is faulty). The main power supply PCB is faulty.
Caution: To clear the error, execute the following in service mode:
COPIER>FUNCTION>FCLEAR>ERR.
Action See the description for E003.
E003
Action
1. State
Turn on the power switch, and clear E002/E003. Thereafter, turn off and
then on the power switch. Does the fixing heater operate?
NO: See "The fixing heater fails to operate."
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Feb 12, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
E243
Main controller PCB
1) Turn offf and then on the power switch. Is the problem corrected?
YES: End.
NO: Replace the Main controller PCB.
Control panel PCB
2) Try replacing the control panel PCB. Is the problem corrected?
YES: End.
Mar 22, 2010 | Canon imageRUNNER 8500 Copier
Getting green interference on lcd tv especially on
unplug your lvds cable going into the control pcb reconnect cable into the control pcb.if this does not work replace control pcb first,then also could be a defective panel.
Jul 15, 2009 | Televison & Video
TV will not turn on
Ok, you stated that you get a green for a second and then a couple of blinks and then, it turns off. This rules out the power board but, its main control partner is experiencing some trauma. Normally in the plasma TV set, the green is a go but, if the PCB(Power control board), doesn't agree, the the power board will shutdown the entire unit after giving a few blinks. Its very important to remember that, the power board and the power control board are two separate circuit boards. In your case, the PCB is down and it will need to be replaced.
Please rate and god bless.
Mar 27, 2009 | LG 50PC1DRA 50 in. Plasma Television
Help quick
The main controller PCB has detected an error in the communication
between the DC controller PCB and the main controller PCB.
try to reconnect all conectors on your machine, check for toner dust on them, realese all wire holders, check the wires,...
Dec 13, 2008 | Riso RZ220 Duplicator
Samsung rs21dpsm
It may be that the air vent is blocked by something as well but the filter is usually behind the air grills.
Thanks J
Dec 24, 2007 | Freezers
Door Lock
door lock blown this sometimes blows tracks off the main pcb behind the control panel. appliance doctor
Jan 29, 2007 | Hotpoint WMA44 Front Load Washer
Samsung RS2630SH Side by Side Refrigerator Logo
440 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
