Please help my daughter is driving us up the wall....
First, I'm assuming you have a Windows operating system. When you first turn on the laptop hit the F1 key (on most computers - her's may be otherwise) to enter the setup mode. You have to do it quickly or the machine will roll right into the operating system start-up screen. Follow the setup instructions until you get to the point where you're at "Secondary Master" for EIDE drive devices. This is GENERALLY where the CD drive is "stationed" in the overall drive device hierarchy. Set the "Secondary Master" for "Auto detect" and then "save and exit" (usually F10). Good luck.
Posted on Jan 01, 2008
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
I want to upgrade the hard drive on my Advent 6001 laptop to a 250gb one. How do I then copy Windows onto the new hard drive as the laptop doesn`t recognise the CDROM as a boot device, not even in the
Running under the assumption that the CD is actually working, have you checked the BIOS settings to indicate that you want the CD to be the first boot device?
Alternatively, some if not most systems will accept an F12 during boot up to query the user where to boot from.
Jan 06, 2018 | Hitachi Travelstar 5K100 HTS541040G9SA00...
I have a gateway 4540 laptop. my daughter gave me a cd to play that she burned from the internet. I put it in and all of a sudden an error msg came - up something about cant find the site and the cd drive...
is there a little hole on the cd rom drive?
if there is one in front of it you can use a small paper clip and insert it in the hole.
push straight in and not at a angle and the tray should eject.
Mar 21, 2011 | Computers & Internet
I installed a new hard drive. on the compaq presario v2000. all im getting is realek media error. i went into bios set default. no resolve. tried cd rom first. no help.jumper pin is outter two verticle....
Does the laptop BIOS "see" the new drive? If not the drive must be "Initialised" first, otherwise it will not recognise you have a drive in the bay. Place the drive in a USB caddy and using another laptop or your laptop with the old hard drive in it, select Control Panel and Adminastrative Tools. Select Computer Management, From the side panel select Disk Management to view selected drives. The disk drive that is connected via USB will be there. Click the drive and select initialise then format and select a drive letter. OR
With the new drive in the laptop bay, set the BIOS menu, on your laptop, to use DVD/CD ROM drive as first boot device.
Place your System disk in the drive and boot from the disk.
Follow the instructions, (if any) on the screen and let the new system software initialise and format the new drive.
Hope that helps
Dec 17, 2010 | HP Compaq Presario V2000 Notebook
My laptop does not recognise cd drive,
it is possible that the drivers for the cd drive is not installed or corrupted, try downloading drivers from the manufacturers website for a more updated driver
May 20, 2010 | Toshiba Satellite A100-S8111TD Notebook
Cd-rom in my daughter's laptop has stopped working. i have an identical laptop and swapped out the cd-rom drives but still does not work. I'm trying to download the drivers for the cd-rom drive but can't...
I believe we need drivers for CD ROM if both laptop are of same models. Can you plese insert the faulty CD ROM to your laptop and verify whether it is working or not. If yes, then you'll have take your daughter's laptop to service center. Could be a problem with mother board.
Please come back and give ratings to my solution if this turns to be helpful for you or also if you need more clarification.
Mar 31, 2010 | Computers & Internet
CD rom drive not showing up in
Common problem. CD driver did not install correctly.
Go to Device Manager. Unistall the CD drive. Reboot.
The Operating System will then rescan, locate the drive, and reinstall the driver.
Good luck.
Jan 09, 2009 | Computers & Internet
Philips DVD+RW SDVD8820 does not recognise burned CD or DVDs
it could be upper and lower filters in registry and system files, use a removal tool called filtercheck 4.6 in (goto the forums and search for filtercheck)
after you downoad, run it, click yes to all filters found to remove. close program.
reinstall your preferred burning app (1 prog installed at a time and test burn)
this is to replace the filter entry that was corrupt
Nov 09, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
