My dishwasher won't drain fully . It still has a bottom full of water after it finished the cycles. We took off the drain cover and it had a lot of "gunk" on the bottom of it. Gross!!! Help!
you may have a part on your machine called a piston and nut, it screws into the soil chamber. it has a gasket on it, and is likely worn from the hot water and you will need to replace this part. not an expensive part. without the model number, i can't say for certain that your machine has this part. but if it does, and it is worn away, all the water will not drain from the tub. hope this helps.
my dishwasher doesnt seem to have enough water pressure to raise the funnel and circulate water. ...
(More)
my dishwasher doesnt seem to have enough water pressure to raise the funnel and circulate water. what could the problem be?
