Question about Fisher and Paykel GWL11 Top Load Washer
RE: won't drain
My fisher paykel gwl11 won't drain. Sure that I or my husband can clean drain pump etc., but not sure where to find part on machine as well as, interconnecting pump and diverter.
I had the same symptoms (washes normally, but won't drain/spin) It would only make a faint hum. I found it fairly easy to lift and tilt back the upper section id by removing the front two screws under the lid. The aggitator came out easily by removing the softener cup and unscrewing the large plastic wingnut inside. The upper plastic shroud came off by carefully removing the eight or so plastic tabs. Once the shroud was off, I could lift out the main wash tub. With the wash tub out, I was able to remove all remaining water from the holding tub with a cup and sponge out all water down into the depression where the pump assembly is located. One screw removed the cover to the pump assembly. Once apart, I found a thin piece of plastic was jamming the pump impeller from spinning. I blew through the drain hose from the back to ensure the drain system was clean. Reassembled in reverse in less than 10 minutes. It worked. Thanks Fixya!!!
Posted on Jan 22, 2008
  • 262 Answers
Fisher /paykel is very easy to work on BUT every thing has plastic tabs not very many screws SO BE VERY VERY CAREFUL NOT TO BREAK THESE TABS the pump(on the early 11) is under the inner tub(and on the later which is the 12 is under the tub chassie)If memory serves me they just dont break every day so I have to back up and regroup every time. you have to take the inner tub out I would recomened having a Fisher Paykel tech not a handy man or just a appliance repair man fix it this is not fun and you can damage the machine very fast if you need and phone #'s to f/p let me know Ive got some that the customer cant get because Im a factory tech for all the name brands including f/p
Posted on Jan 01, 2008
Fisher paykel GWL11 will not power on (yes the circuit is on)
Check the water pump under the machine. These pumps fail, but are easy to replace. Ours was short circuited and actually sparked when the power button was pushed. Same no lights, no power. We had a GWL10 model, but I'm sure the GWL11 is similar.
Aug 13, 2014 | Fisher and Paykel GWL11 Top Load Washer
GWL11 Top Load Fisher Paykel Washer. Sink Drain next to washer backed up into washer. Sink had been recently backed up by paint sludge, husband used sink to clean brushes. Now paint sludge is in Drum...
Yes it can be destructed and cleaned but will need to be done by someone with knowledge such as a service tech which will probably cost you an arm & a leg, or you can try constant hot washes with good washing powder to flush out sludge residue.Failing that
Nov 13, 2013 | Fisher and Paykel GWL11 Top Load Washer
GWL11 washer diplay won't light up or power on. drain pump leaked, replaced both, still nothing
your main board is out very come with a bad drain pump the new pumps and boards come with a fuse to stop this problem. water hit the pump and shorts out the board
Aug 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Ecosmart WA37t26gw2 won't drain
Check your belts and replace if faulty
turn the pump by hand with belt off to see if pump is jammed
still no go, you may have a faulty electronics board.
Oct 30, 2011 | Fisher and Paykel GWL11 Top Load Washer
Top load fisher paykel 2004, mid cycle of wash alarms won't agitate or drain
Hello - No one can help you if you don't describe the alarms, colours of the lights its position on the display. It could be the drain pump but cannot be sure - need some help here...
May 02, 2011 | Fisher and Paykel GWL11 Top Load Washer
GWL11 fisher & paykel washer draining very slowly
Hi just read your posting.Now when you say it 'catches', what exactly does this mean?Was the pump corroded in any way?After the pump drains for awhile is it hot to touch?Best guess on the fault is pump.But I have seen on a machine, the motor controller being faulty.Is your pump the model with an external fan?Have you or can you borrow an electrical test meter to test the OHMS of the pump windings?Please reply with additional information on the questions and I am sure I can help you further.
Jul 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
GWL11 fails to drain
I had the same problem. After bailing out the water, I tipped the machine and saw a knee high panty hose caught up in the fan on the bottom. I removed that, checked to make sure the fan could spin freely, and viola! problem solved!
Jun 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer will not drain
90% chance that is the pump is pumping water at all, there is blockage between the tub and the drain pump. If there is no water coming out of the drain line. either extremely clogged(odd) or pump motor is bad, and windings are not allowing rotation.
May 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel gwl11 won't drain
This machine was made similar to a lighter.When it breaks you throw it away.
Jan 03, 2008 | Fisher and Paykel GWL11 Top Load Washer
Need to replace drain hose
there is a kit available to replace just the part from the back of the machine.normally the drain hose comes with the wiring loom big job.not sure what country you are in.kit is available in australia.
Nov 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
318 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
