Question about Canon PIXMA MP510 All-In-One InkJet Printer
Printer won't turn back on!
Had a paper jam. In the middle of trying to find the problem, printer shut itself off. Removed rear cover and pulled out jammed paper. Printer will not turn back on! I checked all plug connections, which are as tight as I can get them. Help!
  • pub1898 Dec 03, 2008
    I turned the power off during a paper jam and now it has no power at all. I can't turn it back on it acts like a burnt fuse or something
  • 39 Answers
Did you push cancel
Posted on Feb 09, 2008
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
False paper jam on hp laserjet 4345
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
Feb 06, 2013 | Office Equipment & Supplies
Says paper jam, but there is no paper jam
Nov 20, 2012 | Kodak ESP 5 Printer
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
Several sheets entered the printer at the same time and stuck. can't pull them forward or backward.
Step 1 Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
Step 2 To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
Step 3 For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
Step 4 Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
Step 5 Try printing another document
Jan 13, 2011 | HP PSC 1600 InkJet Printer
Paper jammed - how do I get it out?
  • Follow the below steps to clear the paper jam
  • To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
  • For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
  • Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
  • Try printing another document.
  • Nov 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    How can i remove the paper inside the printer
    For the paper jam issue turn around the printer and open the back door to pull the paper.
    and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
    Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Paper jam in hp deskjet 5900 series. how do i correct?
     Follow these steps to remove a paper jam:
    1. Press the Resume button.
      If the paper jam does not clear, then go to the next step.
    2. Turn off the printer.
    3. Remove the rear access door. Press the handle to the right, and then pull out the door.
    4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
      If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
    5. Replace the rear access door securely.
    6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
      printer when removing paper from the front.
    7. Turn on the printer, and then press the Resume button.
    8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
    Jan 29, 2009 | Office Equipment & Supplies
    Canon PIXMA  MP510 All-In-One InkJet Printer Logo
    70 people viewed this question
    old marine
    old marine
