Re: Where is the throttle position sensor located on a...
Remove your air intake hose at throttle body opening. Look at plate across front of the opening, the shaft in the center that it is attached to, will have your TP sensor on the end of it, at the outside of the housing. This may help. (picture)
the service manual has this, buy one, I have them for all my cars for 50 years owned, and I have a scan tool (over 6 year) for OBD2 USA care so I never miss out on CKP or CMP or P03xx errors ever. well they are on the CAM shafts. SOHC is good to hear. step 1 skipped, did not scan the PCm to see what P03xx errors called DTC you have. page 1 in cam CMP error page states Are DTCs P0340, P0344, P0345 or P0349 present? location pages. and below are the SOHC, CMP.
see red arrow below. it must go to the cam and tells PCM which cylinder is fining video
If you are talking about a trouble code for the pressure sensor, the sensor may be telling the computer the fuel pressure is too high. The sensor is mounted in the fuel rail on the engine.
Start by checking your TPS switch (throttle position sensor) located on the throttle body . They turn while your foot pushes the accelerator pedal . TPS voltage goes from 0 to 5 volts and is easily checked with a volt meter .
Should be on the left or right side of the throttle body opposite side of where the accelerator cable attaches.The TPS is a reostat (Variable resister) that is turned by the armature running through the throttle body.
Hi, your truck must use a stepper motor to control the throttle. The computer is getting a signal from the accelerator position sensor and trying to rotate the throttle, but it is having trouble either rotating the throttle or sensing the position of the throttle. If you can give me the exact trouble code, I may be able to say more about what the problem is.
it could be either --throttle body sticking open will cause constant acceleration when u lift off pedal-cableless accelerator [electric gas pedal ]if a sensor or electronic part shorts out can open throttle body causing acceleration- would need to have it diagnosed to find out which problem is correct
