What you might be experiencing based on your symptom sounds like a damaged convergence IC. With any Projection Television that has a damaged convergence IC, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set. With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you. While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need. Their site is http://www.andrewselectronics.com/welcome.aspx And their phone number is a 24-Hour Order Desk: (800) 274-4666 I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
I hope this information allows you to resolve this issue. If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed. If you need further assistance please comment to this post and I will try to help you further. Thanks for using FixYa asnowman I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
there are light waves in the top left corner of the screen...always have been...there seems to be a...
(More)
there are light waves in the top left corner of the screen...always have been...there seems to be a secondary screen behind the main screen...almost looks like something was spilled on top of the tv and ran onto the secondary screen...I took it out and there is no way to clear that up...there doesn't appear to anything on that screen but the picture still has light waves that aggravate me to no end.
i have a hd52w69d tv combo and when you try to turn it on the power light comes on then goes back...
(More)
i have a hd52w69d tv combo and when you try to turn it on the power light comes on then goes back off we was watching the tv and it went off now will not turn back on
