Question about Acer AL1716 17" LCD Monitor
Software app HP Director won't run
Since installing this monitor I can't get this app to run (no problem with my old monitor). I have uninstalled and reinstalled twice-no help. I it possible it is running in background and I can't get to it. When I click on the icon it appears to be loading up but never comes on screen. when I use Ctl,Alt,delete it shows in processes but not in apps. help
  • 75 Answers
Try to update the driver of your acer lcd and removed the driver of your old lcd.
Posted on Feb 02, 2008
Want to instol new hp printer ,i want to get rid of old one
Unplug old one and plug in new one. May need to insert cd. Go to control panel, printers, right click old printer and select delete
Jun 16, 2011 | HP PSC 1315 All-In-One InkJet Printer
I accidentally deleted my hp director icon from my computer i dont know how to restore my hp director
If you have just deleted the icon from desktop and not uninstalled then we can put a shortcut back on desktop
Click on START button
click on MY Computer
OR
Open MY Computer icon from Desktop
Open Local Disk C:\
Open Program Files
Open HP Folder
Open Bin Folder
You will find a file by name HPDIREC
Right click on the file name and Click create shortcut on desktop ( this icon will not look exactly like the HP Director icon you deleted )
Close the window and you will find the HP Direct icon on desktop
If not, you can uninstall the software from Add/remove programs under control panel and install the latest software for your printer. Click on the download button below to open HP website to download the software by selecting your operating system
Download
*Note : HP Director is not longer designed by HP. IT is replaced with a new Software called HP Solution Center
Oct 21, 2010 | HP PSC 2210 All-In-One InkJet Printer
Scan picture - Message: Sorry scanner could not be initialized. (Scanner Not Found)
There are several possibilities. Did you launch the scan from the computer or the scanner buttons? Stop at the point that works in these various trouble-shooting options.
1) Make sure that the HP Digital Imaging Monitor monitoring program was running if launching from the scanner. (Make sure the HP driver is installed not the generic OS driver.) The software is available from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1146331& select your OS and then press Next. Click on Driver to download.
2) The scanner requires bidirectional communication with the computer. Try a new data cable and a direct connection (if you use a USB hub or print server). Try a different USB port and make sure that the ports aren't disabled for security or power-savings. (The first is in the Device Manager; the second is part of the advanced settings of the Screen Saver.)
3) Use the HP Director or Solution Center to check the scanner status (this is in the full-software form HP). If it is available for your OS, you should uninstall the generic OS driver and disconnect the data cable before installling the software. Even if you have this installed, check if you need to patch the software.
4) Download and run the HP Scan Diagnostic Tool to test the scanner. http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-926&h_lang=en&h_client=s-h-e016-1&h_keyword=dg-SDU&jumpid=ex_r4155/hho/ipg/ccdoc/scan_diag/ .
5) Can you acquire scans from the computer with non-HP software? Windows XP, Vista and 7 can acquire scans from Paint (File > Import from Scanner or Camera). Vista and Win7 also have Windows Fax and Scan (New Scan).
6) Disconnect the data cable from the computer. Then Start > Run > regedit . This launches the registry editor (Run as Administrator for Vista or Win7). Back up the entire registry first (File > Export, follow the steps you see and select all.) Locate the HP registry item: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {6BDD1FC6-810F-11D0-BEC7-08002BE2092F} and highlight the section in brackets. Right click on Lower Filters (string value) and delete it. Close regedit (Save changes) and restart the computer. Reconnect the data cable after the reboot.
7) Uninstall and reinstall the HP software driver (again remove the data cable after the uninstall and keep it unplugged until the software requests connecting the cable).
8) Check if you need to update the BIOS or USB drivers for your computer (see the manufacturer's site) and Windows Update.
9) Check if the scanner runs if connected (after software install) on another computer. If it doesn't work on another computer, you probably need to replace the unit.
I hope this helps.
Oct 08, 2010 | HP Photosmart C3180 All-In-One InkJet...
Cannoy access HP Director. Error message: -
Uninstall the HP software:
Start
Control Panel
Add/Remove Programs
Select HP
Remove
Restart.
Re-install the software.
Access HP Director.
Sep 11, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP Director is missing
This site has a all in one printer disk>
http://thepiratebay.org/torrent/4345425/HP_Officejet_9100_Series_(9110__9120__9130)_All-In-One_Printer_D
The disk has HP Director on it...
Jul 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
WHERE COULD I DOWNLOAD THE HP DIRECTOR SOFTWARE
It wont work with xp, it will only work with windows 2000 and lower
Nov 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
No HP Director
I had this same problem when switching to our new pc and still running xp. I was told that the new pc was installed with the new version of the program and had to uninstall the new version and load the old from the cd in order to use the programs I was framiliar with. Check with HP tech support and have them help you through the uninstall.
Dec 10, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Director
First thing you should do is uninstall the HP director software you have if it is installed and doesnt work. Uninstalling will depend on your operating system - post again with details and we can talk you through it if you are unsure how. Next you need to go to this link; http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=374568&lc=en&cc=us&dlc=en&submit.y=4&submit.x=9&lang=en&cc=us Select your operating system version and download the software. Install it, follow the on-screen instructions and you should be able to access it. Any problems doing this, please ask again, Hope this helps :)
Apr 05, 2007 | HP PSC 1315 All-In-One InkJet Printer
Hp director
It could be about this: I had same problem until I found a review somewhere - even HP technical support was totally useless - until HP FINALLY decided to up date its drivers to account for my/many people's downloading of Internet Explorer 7. As this is now done, and you cannot easily uninstall IE7 and go back to IE6: try again (1) HP Director and if not (2) I think update drivers or (3) uninstall / reinstall. Hope it helps.
Apr 04, 2007 | HP PSC 2410 All-In-One InkJet Printer
Acer AL1716 17" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
