Question about Hitachi 50V500 50 in. HD-Ready LCD Television
LCD TV NO DISPLAY OR LOST DISPLAY PICTURES - Hitachi 50V500 50 in. HD-Ready LCD Television
  • 2 more comments
  • KIDO12 Apr 22, 2008
  • smithy0797 May 10, 2008
    i have a Hitachi lcd (model 26ld6200) which when you switch on there is just a black screen with sound the power lights are on? About 6 months ago i took it to be repaired as the picture was flickering, i was told that it had dry ends? which he has sorted out but around 3 months ago it all started again and know no picture at all.
  • robert ashby May 19, 2008
    my lcd plays but after 15min, the picture gets distorted then it goes blank then it comes back on. this goes on back and forth until i cut it off for a few hours and turn it back on. then i can get another 15 min without interuptions
  • luke2358 May 25, 2008
    I also have the problem of sound but no picture.When I turn the tv on, all three lights come on- the lamp (which is red when the tv is off),the temp and the power.After approx. 5 seconds the lamp and temp go off the tv should come on but doesn't.The blue lite then begins to blink for approx 10 seconds then the sound comes on for about 15-20 seconds then goes off again. This process continues on with the blue power lite still blinking, the the sound coming on and off every 15-20 seconds. Any ideas of what the problem is???
  • 579 Answers
Can you say more about what is going on? What are the little indicator lights by the power button doing. The most common problem with these is lamp failure.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Posted on Jan 01, 2008
I brought Sony Bravia KLV-32U300A 32 in. HD-Ready LCD TV 4 years ago now it's screen fill with lots of tiny lines difficult to see pictures. i submitted it to service man. he told me problem is on...
This is the main fault, that most Sony LCD TVs. The actual cause is with a faulty T'Con board. For most Sony LCD sets, this part [T'Con board]; will be a built in part with its display panel, and can't be replaced. Display panel replacement is the only repair work. Nothing can be done, even for the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Mar 03, 2016 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Best plasma TV HDMI
None.All Plasma tvs designs are alway have high heat output and consume alot more A/C power energy than any other tvs designs out there.Tvs like CRT-tube tvs,DLP tvs -Projection tubes and projection lamps tvs,LCD-flourescent tubes tvs as Liquid crystal display screen tvs.All these tvs designs are all good tvs designs to buy but the pictures display and screen lighting and the sharpness of the pictures never have and able to compare high enough qualities as a display picture on the screen output to a Plasma screen tvs,until now LED-tvs are LCD and LED screen display combine to make it better and brighter technologies and now are good enough to compare to a Plasma screen panel tv.So buy a LED tv will get less heat output and comsume less A/C power energy too and it is good enough pictures qualities too.To compare too as a plasma screen panel tvs output.
Oct 28, 2011 | Televison & Video
Half the screen is blackened for about a half hour...then its fine, what is causing this? How can I fix it?
First, A new TV LCD should not display malfunction. Liquid Crytaline Devices allows the program to display across the screen area, also capable of high definition alterations either user adjusted or program device alterations to suit conditions. However, three technical requirements makes achievable TV experiences. First, the connection cables to the LCD screen should be firmly fastened. Check all connection cable connections from pheriperal devices to the TV firmly fastening to prevent media seepage. Second, LCD TV screens display fliud expressions when pressure is appplied from an external scource on the Screen. Over exerting the screen with a weight should produce distorted pictures. Third, attempt to ascertain the media that is being played on the TV. For example, broken movie disk would appear distoprted on the LCD screen because is designe for sensitivity. A muttated picture displayed on the LCD screen usually is tracable elsewhere to connection devices orpheriperals. Brand New LCD TVs are expected to least malfunction unless were physically damaged. Goodluck
Jan 08, 2011 | Vizio VO47L 47 in. LCD TV
Display shows invalid format after connecting computer in LCD tv
The PC video resolution is too high for the monitor to display, you need to set it to the native resolution of the monitor to get the best pictures. Please read here:
Failed TV and Monitors:
Sep 24, 2010 | LG 22" FLATRON LCD Monitor
White display LCD TV
The screen glowinh white mean it is not getting voltage to the LCD controller, the ribbon cable may have come lose. You need to open it up and look inside.
See some pictures here:
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Pentax Optio s50 The LCD display has lost some pixels and now has a circle of black spots on the screen. Is there anyway to fix this or is it time for a new camera? I can't just look through the view...
If pictures taken in Auto mode look the same on a computer (or when printed) as on the LCD display a Sensor fault is indicated. If the Computer image is OK the LCD display on the camera is faulty.
Assuming your camera is out of guarantee you could request a quote for repair but beware the "Minimum Charge" some suppliers impose just to tell you how much it will cost.
Apr 27, 2008 | Cameras
No pic framing on LCD display - playback is OK
ON digital slr cameras there is no pic framing on the LCD display.
Apr 25, 2008 | Pentax K100D Digital Camera
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
Either bad connection with the LVDS cable, defective LCD controller, or even a defective LCD panel. Can you post pictures?
Nov 13, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
498 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
