Question about E-Machines eMachines Desktop PC
E machine the moniter keeps saying its going to sleep and the big blue E keeps blinking on and off. Thats the button you push to turn the computer on and off. Husband is in Iraq. PLEASE HELP ME
  • 205 Answers
How long does it take for this to happen? Try this:
Click on Start->Control Panel and double click on Power Options. Check the settings on the Power Schemes and Hibernate tabs. You may just need to alter these settings.
If you find this helpful please rate the solution. I don't get paid for this or anything I'm just trying to help.
Posted on Jan 01, 2008
Came home to find computer off. It was left in sleep mode. The moniter keeps saying there is no signal and the keyboard has no power.
If its truely in sleep mode, and won't come out of sleep mode. Unplug the computer from its power, hold the power button down for 5-15 sec, then wait 2-5 full minutes. Then plug it back in, and turn it on.
If that doesn't work it is NOT stuck in sleep mode. Most dell computers I've worked with the caps go out in the power supply and/or the motherboard. I would next clean out the computer with canned air, check the caps on the motherboard, and in the power supply. If there are any bad caps, replace them, and it should fix it. Hopefully though the above paragraph fixes your problem.
Sep 13, 2013 | Dell Dimension 4600 PC Desktop
Fixya solutions:: my question is about my Hewlett Packard model p6-2003W desktop blue light on ucp and moniter going to sleep and shutting off when I reboot or shut off power they both come on and I a
The problem can be correct in the control panel power options..
select hig performance as the preferred plan,
click change plan settings
change both sleep options to never>>
this is caused by a corrupted display settings in the registery and needs to be reformatted or restored using the factory restore disc to fix the problem. the above solution will work just remember to put your system to sleep manually and turn of your monitor.
Dec 29, 2012 | HEWLETT-PACKARD Computers & Internet
Question about my HP desktop model p6-2003 computer blue light on and moniter going to sleep moniter going to sleep
in control panel, select the power Options,, Change the preffered plans to HIGH PERFORMANCE then click on change plan settings, change turn of diaplayto never and put computer to sleep never... Remember to turn on your screen saver and put the pc to sleep manually when not using it.
this is a common problem and caused by corrupted registry entries. The popper fix is to reformat or restore the system.
Dec 29, 2012 | Computers & Internet
Within the last few days the moniter "blue light" when it is turned on suddenly turns yellow and the screen goes dark. I move the mouse briskly and turn the moniter off and on again and...
You should check the "Power Options" when the computer "Sleeps" & "Hibernates". Go to the "Control Panel" if you Win 7 or below, if you have Win 10 just type "Power" on the "Search Box" on the bottom left of the screen and then click "Edit a Power Plan" and set when the Computer "Sleeps" and when it "Hibernates". Basically when you move your mouse you are waking up the Computer from "Sleeping" or "Hibernating". Goodluck.
Dec 14, 2017 | Acer Brand ACER P191W 19" LCD Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
DGM screen monitor problem ''22
the light blinking makes me think that the moniter is going in to sleep mode...try turning the computer on while the moniter is not pluged in(pull the blue vga cable) wait a bit then move the mouse around then plug the vga coble back in...(while the screen is already on)
Jul 09, 2010 | Computers & Internet
My pc crashed and i had to switch the pc off by the switch
I agree it must be a PCI slot or video card problem .Try to change the videocard.
Jun 05, 2009 | E-Machines eMachines Desktop PC
A blue box pops up on my screen and I can't get rid of it
i can't see the box, why not post photo, be like 2nd ever to do that here.
the menu button unlocks per the manual,
push said LCD menu button for 10seconds and it unlocks.
the lock is to keep kids from messing up your LCD controls
if you see sleep timing in the LCD turn that off, or pain happens.
the LCD OSD menu is called that OSD, on screen display.
lost the manuaL>?
is the unstated PC turned on, if not the LCD will complain.
NO signal, no sync, out of range, etc.
RTM?
its all there. free, posted here vast times.
https://www.manualslib.com/manual/71406/Hp-Pavilion-F1503.html
Dec 24, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Mikomi ak-808u keyboard
When you press your power button your system goes to sleep mode as per your system settings. To awake your system just press any key or 'Awake Key' (if its present on your keyboard), then your system will be back. No need to wait.
Thanks
Iqbal
Mar 11, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
50 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
