Question about HP OfficeJet 6210 All-In-One InkJet Printer
Very slow printing
I recently changed my black cartridge and after that my 6210 prints very very slowly. It takes 5 minutes before it prints one page. First it failed to align cartridges (after installation). I tried many things suggested and nothing worked. Any suggestions?
THANKS!!!
  • aco_e Dec 04, 2008
    cleaning nozzles worked.
    Thanks
  • 16 Answers
Try to make a photocopy first from the printer itself, if it can print faster then the problem is on the computer,if not then follow the steps below:
Clean the printheads, clean the nozzles, if it still print slowly, remove the cartridges and clean the nozzles. If these steps does not resolved the problem then try changing the cartridges, maybe there's something wrong with the cartridges itself. After changing the cartridges, try to print again, and if its still the same then just post it here and ill try to find another solution for you.
Posted on Jan 05, 2008
SLOW PRINTER
You have a cartridge problem.
This condition is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
May 03, 2012 | HP Office Equipment & Supplies
HP Office jet printer slow
I think it's that black cartridge!
The problem you've described is typically caused by one of the cartridges failing. Try removing the black cartridge and printing (not copying) a test page. If this prints at near normal speed the black cartridge is at fault and should be replaced. If the printer still prints slowly then put the black cartridge back in and remove the color cartridge, then print a page. Replacing the cartridge that causes the slow printing with a fresh cartridge will resolve the issue.
Assuming the cartridges are original HP (not re-manufactured or refilled) you can check the warranty status by CLICKING HERE
Let me know how you make out.
Ben
May 03, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Brother DCP-150C - just installed a new black cartridge (changed colour cartridges last week!) - printer will print but page comes out blank??
This may be because ink is clogged in the printhead. ? Place the clogged cartridge in about 1/4 - 1/2 inch of warm water for a few minutes. When ink starts to slowly leak out take the cartridge out of the water and dry it using a soft cloth to "Q-tip." Then place it back in your printer and run the print head cleaning utility that comes with your printer software. You may have to run this 2-4 times before printing quality is reestablished. If your print head is destroyed, as can happen, you will have to buy a cartridge and refill that cartridge before it is fully empty.
Feb 19, 2010 | Office Equipment & Supplies
My HP 5610 is printing extremely slow.
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides..
Oct 05, 2009 | HP Officejet 5610 All-In-One InkJet...
When making copies using the autofeeder a black line appears down the middle of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge
Aug 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
DELL 1720 PRINTER PRINTS VERY SLOWLY.
Whenever I have a customer tell me their printer seems to be running slower, 9 times out of 10 its what they're trying to print...not the printer. Heres a couple of things to do and ask yourself. First I'd do a test print from the printer itself. Does it kick it right out? Then go to the printer folder on the computer, right click on the printer, go to properties..click print test page. Does that come out pretty quick? Okay if they seem relatively fast then its beginning to look like something other than the printer. Try printing the job that seems to run slow. Then try printing from a different program. Is there a difference in speed? The job that prints slow may have graphics or require more memory then it use to. Perhaps you changed the graphics content on the page and the printerr is taking more time to process it. Adding more memory to the printer can help that.
Did you make any software change to the printer about the same time you noticed the slow down?
Have you changed the font color in the computer to something other than black for that particular print job? I've seen monochrome (black and white) laser printers slow down because its trying to convert the job to say violet or some other color. Its a black text printer and apparently printing color confuses it ..lol My bet is..if you really sit down and think back...something changed in the content of what your printing thats taking it longer to process it. Hope this helps!
Jul 10, 2009 | Dell Office Equipment & Supplies
Hp Officejet 7210 all-in-one
Random Extremely slow printing !! same !! changed cartridges . i cant figure out the problem !
Nov 21, 2007 | HP Officejet 7210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
260 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
