Question about Samsung TS-H552B (10 Pack) Burner
Dvd ram issue
Hi am having a problem with my cpu.. it cant read any newly installed device and it this case its the dvd rom. it works and runs properly but the computer just wont read it. it doent recognise the device at me out please
  • 796 Answers
Try installing the driver which they gave along with the hardware or update your operating system...this should solve.
Posted on Jan 02, 2008
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
I am trying to reinstall windows xp prof but i keep getting the blue screen and the system keeps shutting down, i have tried a different hard drive but get the same error.
unplug all devices except the hard drive and 1 cd/dvd rom drive. disable the audio device and any other unnecessary devices within the BIOS and remove all pci cards. remove all but 1 ram stick, and try using different ram sticks, one at a time, while trying to boot. if it boots, with 1 ram stick, 1 hard drive and 1 dvd/cd drive then try adding/reenabling the other devices one at a time, until you find the device that keeps it from booting.
if your pc wont load with just a hard drive, cd rom and 1 stick of ram, then it is prolly trashed. if removing/disabling one of the other devices (such as the sound card or the modem card) allows it to boot, then you have found what needs replaced.
Nov 06, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
I have upgraded my pc.The 2 CD-DVD RW dr ,do not play or record
I advice you to remove one driver and look whether the other is working. Check both the drives this way. Once you find them working, you can get back to your old system, that is, how it is now. This is not based on any logic, but it may work as your problem may be that your newly upgraded system got confused with the two drivers.
Apr 12, 2010 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Dvd rom reads only dvd not cds
hi frnd...
try finding out the name of Ur DVD rom.. it will be available in the DEVICE MANAGER.. to access device manager just type DEVMGMT.MSC in RUN option... once u have located the name of the DVD drive .. just go to the DVD drive vendors site and download the firmware of the dvd drive and instal it and restart ur system it will work fine.. while installing the firmware the LED on the drive blinks...
Oct 01, 2009 | Computers & Internet
DVD rom can;t read from first cd
I have had the same problem many times. Solutions can vary but the first thing I would do is use a cleaner/repair on the CD. The ones you use on movie DVDs will work. If this does not fix it, there might be lint or something on the laser light. I use one of the Q-tips on a long stick to gently clean the light area. If this does not fix it, I usually resort to installing another DVD. Or you may be able to use one of the external DVDs if your computer recognizes it as a boot device.
Oct 01, 2017 | Toshiba (K000816870) for Satellite 1100,...
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
Nov 12, 2008 | AOpen AK77-8XN Motherboard
Hp invent p dvd940i does not see dvd disk
1. check your system meets the requirements for your device:
• Minimum system requirements: 800 MHz Intel® Pentium® III
processor or equivalent, 1.6 GHz Intel® Pentium® IV processor or
equivalent recommended (Actual drive performance depends on PC
• 128 MB RAM (256 MB RAM recommended for video editing)
• 1024 x 768 video resolution with a minimum of 16-bit color required
for DVD authoring and editing
• Video capture: IEEE 1394 interface or analog video capture device
• Minimum hard disk space requirements: 1 GB free for included
software installation, 10 GB free for DVD video disc creation (18 GB
free for double layer). Internet connectivity recommended for software
• Operating system compatibility: Microsoft Windows XP/2000
Professional SP4, Windows XP Professional x64 edition, and
Windows Server 2003
2. Have you install the sowftware that came with your device?
3. is your system recognizing the hard drive (go to start>run>type devmgmt.msc and press enter> and look under cd/dvd rom drives... is your device listed? is it showing with a ? unknown device or a ! next to it's name?
a. if the device is not listed chances are you didn't set up the jumper correcly when installing the device or the device may not be powered or there's an issue with the data cable connectd to the device and the motherboard, check your physical setup.
4. check the removable media is in fact compatible with your drive: this is the compatibility list
• Device write media compatibility: CD-R, CD-RW, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, LightScribe CD-R,
LightScribe DVD+R, LightScribe DVD-R, 4.7 GB single-sided/9.4 GB
double-sided DVD-RAM (2.6 GB single-sided/5.2 GB double-sided
media not supported)
• Device read media compatibility: DVD-ROM, DVD+R, DVD+R DL,
single-sided/9.4 GB double-sided DVD-RAM (2.6 GB
single-sided/5.2 GB double-sided media not supported), CD-R,
CD-RW, CD-DA, CD Extra, CD-ROM (Mode 1 - Yellow Book),
CD-ROM/XA & CD-I Ready (Mode 2/Form 2 – Green Book),
Photo-CD (single and multi-session), VCD, CD-Text
data taken from
Sep 28, 2008 | HP Computers & Internet
DVD RW Will Not Read Media
try the filter check 4.6 tool from
remove any found and restart.. this usually does the trick.
Mar 17, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
