Panasonic viera plasma no signal
12 months old. Switched off yesterday around 2pm and now cannot get picture on TV banner still displays programme that was on when last switched off but says "no signal" . Can play DVDs no problem.
  • NORSTAR May 08, 2008
    When I turn the tv off at night and then turn it back on the next night the picture from the channel is frozen on the screen . If I change the channel it will correct the problem.
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
Posted on Oct 31, 2007
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
  • 2559 Answers
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Posted on Jul 29, 2009
  • 152 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
  • 1077 Answers
SOURCE: what does it mean when my plasma tv turns off by
Basically when it turn itself OFF automatically all the time, the TV goes into "Protection Mode". This happens when there is a damaged circuit board inside the need to be replace and turn itself OFF to protect the other ones from being damaged.
A TV service tech will have to look at it to find out which boards need to be replace. There are about 7 different boards in your TV that would cause this problem.
Posted on Nov 02, 2009
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
How do I get my tv to display full screen?
Depends on what you are doing. Sometimes the "full screen" is dependent on the signal coming into the TV from a cable box. Check the setup or menu function on both the TV and whatever input signal you are using. You didn't say what TV and what source i.e. cable supplier, antenna etc. Remember that an HD tv doesn't always display a non-HD picture in full screen.
Aug 05, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
My Panasonic Viera Tc-p55gt31 has no picture and no sound
One of the circuit boards has a burnt connection. Look around each of the heat sinks to find the popped plastic circuit. You can also dismount the board and look on the bottom for a burnt mark. Check the number of blinks from the LED. That will tell you which board is bad.
Feb 10, 2013 | Panasonic " VIERA 55"" Class / Plasma /...
Panasonic plasma screen
If you are talking about a tiny crack in the screen itself you are done.
The Plasma display Panel (PDP) is a sealed unit with an inert gas inside--even a tiny rupture is fatal= cost of the panel alone will exceed the price of a new set.
Apr 30, 2012 | Panasonic TCP60S30 60 Class Viera Plasma...
Viera TH-50PZ83U, 20 months old, used nominally (average 15 hours a week). The screen will intermittently flash red, sometimes for a few seconds, sometimes for more than a minute. Imagine the entire...
The main Tuner signal board have problem.That the board,where the broadcasting signal cable plug into it.U have some skills,like take things aparts and put it together again?Yes,than.Try website like buy a refurbish Tuner signal board for the replacement.Or pay the shop for part and labors they'll to do it for u.
Oct 21, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Power light is on but no picture
If its only 2 months old by all means call Panasonic for service...
May 19, 2010 | Panasonic Viera TH-42PX80U Plasma TV
We had a vertical line about 2 inches wide and going from top to bottom on our 42 inch viera that was a light green-barely interfering with picture. Now that area has gone black while the rest of the tv...
It is either the plasma panel itself or a connection problem, either way it will need to get serviced. Suggest you find receipt and phone Panasonic.
Sep 25, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Televison & Video Logo
1,377 people viewed this question
Top Televison & Video Experts
