Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
No av5 in menu
My tv has a av5 dvi connection on back but no av5 on tv wheres it at how do you see it cant find the channel
    Problem Solver:
  • 7 Answers
It becomes visible after you hook up a dvi to hdmi adapter
Posted on Apr 21, 2008
Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
Mar 10, 2011 | Philips 32PF7421D 32 in. LCD HDTV
I have an DVI to HDMI cable running to my Playstation 3. The playstation reconizies the connection. When I search the tv for the connection I connot find it.. The back of the tv says the DVI input is...
Did you ever find a solution to this problem? I have the same model TV and I cannot get anything to display from a DVI video source. Anything "pure" HDMI like a DVD player, XBOX 360, or media streamer, work fine. I now have a PC connected to the TV. The PC has an HDMI port and works fine on 2 LCD TVs I have at home but not this one. I'm starting to think it's a wierd HDCP thing.
Dec 03, 2009 | Philips 51PP9100D 51 in. Television
I have an r52wh74 tv. cant get it to display 720p
Hello Matiki64:
Yes this television does support 720p and 1080i. Hear is something that might solve your problem or at least get you going in the right direction.
Problems with DVI-HDTV Connection
• Make sure the DVI device is turned on and the cables are firmly connected. If problems still occur, turn off your device. Re-connect
your device. Reset the power by unplugging the power cord and plugging it back in.
• If you are tuned to the DVI-HDTV input and you’re receiving Unusable Signal message on-screen, contact the manufacturer of the
DVI device for further assistance.
• If you tune to the DVI-HDTV input and you see snow, the video goes in and out, or the video takes a long time to appear, your DVI
device is having trouble sending video information to the TV. Re-connect your device. Reset the power by unplugging the power
cord and plugging it back in. If problems persist, try connecting to the Y Pb Pr jacks instead if they are available or contact the
manufacturer of the DVI device for further assistance.
• If you have bars on each side of your picture, the device you connected might have a switch or a menu option allowing you to
change the picture format output that will fix this. Choose either 720p or 1080i.
Sep 22, 2009 | RCA Televison & Video
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Screen changes between color as a demo function.no signal
Gateway was sued Class action over LCD's and Plasmas they sold over a 2 year period. They resell 3rd party TV's that were very faulty, an immature design.
Here's what I learned about mine, which makes it limp through as a Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input there is an option called "Factory Mode". scroll down to it with the CH buttons and select it with the vol button. The scroll to "initialize eprom", select and confirm it. After the "Waitting" words disappear, make sure you have a TV source connected, Then turn the TV off and on, using the hard switch in the back. The TV input should be defaulted to channel 10 or 11 now But you select a TV channel that has no TV signal on it (like channel 1 for example) , the whole TV input side will refuse to let you select it again, and you'll have a blank screen and have to start over.
That takes care of the blank screen thing Now the other problem is parental control is defaulting to "ON" or something, and you can't program channels. With the TV input Main Menu engaged, select "Setup Menu." If you have this problem, then you'll only see 2 options, all the TV input and channel programming options will be missing. You have to select Parental Control, and when it prompts you for a password hit the volume > button 4 times (or just wait for a minute.) This should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I select cable, it does better if I select "AIr". But at least it funtions - kind of. If you switch to your computer input, you probably will have to switch the monitor off and on from the back panel again. Mine always starts up with the menu onscreen. All this might bve less trouble if you have a the remote, I don;t know where mine went after the last move.
Good luck, and hope this helps.
Billy K.
Sep 24, 2008 | Gateway LCD26TV 26 in. Television
Blank Screen/Powers up, Power LED can be switched from ON (Green) to STANDBY (Red)
Billy K.
Mar 23, 2008 | Gateway LCD26TV 26 in. Television
Philips Projection model #51PP9303H17 AV5 input not working?
After many hours of research, I was able to fix the missing AV5 channel. I had to access the service menu using code 062596 and the Status/Info button on the Philips remote. There was an error message that had to be cleared and then AV5 needed to be turned on in the options menu. While I was in there, I also turned on the WSCR option, giving me two additional wide screen aspect settings that had also disappeared. I advise you not to go into the service menu unless you do your homework and document each setting before you make changes. Good Luck!
Nov 29, 2007 | Philips 46PP9302 46" Rear Projection...
26" TV is inop
repost
Billy K.
Nov 06, 2007 | Gateway LCD26TV 26 in. Television
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
