Question about Enterasys Other Network Devices
Network troubleshooting i wana ask about some projects about networks troubelshooying hope u help me with that by giving me a problems with solving (my email is) thank u for help
  • 1346 Answers
SOURCE: yahoo does not start..
Not enough info..............
pc or laptop?
wireless or high speed?
Posted on Jul 31, 2008
0 characters
1 Points
What is desktop troubleshooting?and also network troubleshooting?
desktop troubleshooting refers to the repairing of the desktop computer. A desktop computer is composed of CPU, Monitor, Keyboard, Mouse and other external peripherals such as printers and other devices.
Network troubleshooting refers to the repairing of network trouble that may be in Wired or wireless network. A network in computer terms, refers to a group of computers interconnected to each other via wired connection or wireless.
Feb 07, 2011 | Other Network Devices
I want to remove st bernard iprism
It appears to be part of the ASK toolbar. Remove that from your system. I had this as well. I was infuriated, what software was blocking sites from me? They don't have my permission to block sites! I uninstalled the ASK toolbar and the problem was solved. Give that a try!
Oct 28, 2010 | St. Bernard Software iPrism (ipaps03751)...
How do i establish a subnet with a B address
Subnet mask for 86 PCs is more than 64 and less than 128. it means that subnet mask is
You can have PC IP address in range -
Apr 21, 2010 | Other Network Devices
Unable to log in on network. Error message ''The domain can not be found'' what is the cause of this. Have logged in as Local Administrator to find IP address How do I fix this
If this problem just started on a network that was working try resetting (unpluging) the router and modem. Another option is to do a "repair"
I assume this is a wireless connection.
Open your wireless network connection and go to the support tab.
Here is where you can do a repair. This will reset your network adaptor.
Try this and it should solve the problem.
Nov 08, 2009 | Other Network Devices
I want to know my computer have wireless connection
Try this:
1. Go to Control Panel>Network Connection>There will show connections by any network (WLAN, LAN, etc.)
2. Did wireless icon on your task bar appear? If yes, it's meant you're working on wireless connection.
Hope that will help! Feel free to ask me =]
Jul 08, 2009 | Other Network Devices
Unable to connect to wireless network
check your network IP and put one in the same classe of the wireless network. For example if you router IP is then you must configure your IP like: (instead of "1" you can choose a number between 1 and 253)
Nov 08, 2008 | Other Network Devices
Centrios internet radio gives dhcp timeout
This is likely because out of the box, the firmware for this unit doesn't support WPA2 and even certain variants of WPA. I recommend: configure router for WEP or even open (i.e. unencrypted) connection, connect unit, go to setup/update firmware and let it update from network, power cycle, reconfigure your router for WPA or WPA2 security, attempt to reconnect unit to wifi. The updated firmware supports more formats and may allow your new router's config to work. You can also try doing the firmware update over the wired LAN port. Hope this helps.
Sep 27, 2008 | Other Network Devices
Networking problem
configure your local nw with static ip, might solve ur prob.
Sep 17, 2008 | Other Network Devices
Limit or no conectivity problem
I understand that you are using the Windows Internet Connection Sharing to share your internet connection to your other computer.
If you don't have a router to share the connection then you are using Windows ICS connection.
When you enable ICS, the network adapter connected to the local area network is assigned a static IP address of
You can check this site for more information
You can try to connect the two computers first without the internet connection.
Example : PC A
You can set the IP addresses manually, just set the tcp/ip properties and from that area you can set the IP address manually.
And for PC B
You dont need to set the ip address for the gateway and dns since you are just testing the connection of the two computer.
They should belong to the same workgroup example HOME and set the computer name to PC1 and PC2.
You can right click MY COMPUTER then select PROPERTIES then you will able to see the computer name.
To start the wizard
Choose Control Panel from the Start menu.
Click Network and Internet Connections, and then click Set up or change your home or small office network.
Mar 05, 2008 | Other Network Devices
Setting up my HOME network! HELP!!!
Sounds like something is not right with the sharing... Assuming that computer 1 (the computer with the printer) is sharing and everything is set correctly, I would change the workgroup name. Instead of using "MSHOME" use say some basic word like "example" or some other name.
Ironically for my workgroup here I call it "StarWars"
needless to say my printers and everything shares just perfect. When you use "MShome" there's restrictions on what XP professional and XP home machines see on the network. I changed the workgroup name and that solved that problem.
Be sure to put all computers on the same workgroup name that you pick. You can even choose your first name if you want.
Dec 29, 2007 | Other Network Devices
Other Network Devices Logo
15 people viewed this question
Top Enterasys Other Network Devices Experts
 C. Dante
C. Dante
Are you an Enterasys Other Network Device Expert? Answer questions, earn points and help others
