Dell "Inspiron 2200" PC Notebook
Problem for Dell "Inspiron 2200" PC Notebook
Will a bad battery keep a laptop from turning on
By jwebb0214 on Oct 26, 2009
will a bad battery keep a laptop from turning on. the laptop will not turn on unless you take out the battery and use the a/c power supply only
Solution #1
posted on Oct 26, 2009
Not Rated)
cyberdyers
Rank: Guru
Rating: 86%, 163 votes
Good day sir/maam, anything bad on your laptop is not good, if you are in doubt about the battery being bad, read the text written on your battery, you will get the information of how much voltage is the full charge of your battery, 9 volt, 12 volt 15 volt or 18 volt, depending on the make and model. Using a voltmeter measure the voltage across its terminals. If the charge is up to full, the battery is good, if the charge is low even if you charge it for an hour, your battery is bad. replace it.
Was this helpful?
Yes
No
Solution #2
Not Rated)
fredtmccoyjr
Rank: Wiz  Dell StaffDell Staff Computer Hardware  Expert
Rating: 85%, 113 votes
if the battery is bad, yes. Also, if the batter charging circuit is bad, yes. The thing to do is get that battery tested in a shop, or, have another battery like it to try. Batteries are expensive and only have a 1 yr warranty. But, most people do not use the batteries because they are on an AC plug.
Was this helpful?
Yes
No
Popular Solutions for Dell "Inspiron 2200" PC
Questions and Unsolved Problems for Dell "Inspiron 2200" PC
Do you recommend Dell "Inspiron 2200" PC Notebook?
Answer
Answer
I closed my laptop screen when i open, it was not started, i switch off then restart again it is not... (More)
Answer
unable to load windows and unable to complete start up repair from start up repair cannot choose... (More)
Answer
I have this aspire notebook and it is only 2 months old. For some reason, the speakers are very... (More)
Answer
on warhammer 40k dawn of war 2 i put the install code and it says an error i looked everywhere and i... (More)
Answer
no sound thru hi fifrom headphone sockett
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
