i just paid $350.00 for a lamp replacement on my wd-57732 model m itsubishi tv. During the replacement the repairman said that I needed a optical engine replacement in addition to the lamp. I can't find this part on line. What is it & what does it do?
The Optical Block is where the Video and Light from the Lamp is processed then projected to the screen. It is one of the most expensive parts of the set. It cost probably 800.00 to 900.00 maybe more by it's self. You will not be able to find it on line because Mitsubishi keeps a very tight hand on them. Why did he con-dim the Optical Block? I would call Mitsubishi and see if they could help with the repair cost. Their phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thanks for the great answer. It told me not to ever buy a DLP rear projection TV again. To many parts to replace.
Thanks again fot the learned answer
" - jwd2115
TV doesn't respond to Remote. It ignores the commands given and then shuts down... then the Timer...
(More)
TV doesn't respond to Remote. It ignores the commands given and then shuts down... then the Timer Light blinks until I unplug the TV.
mitsubishi tv diamond is broken. it just turned off for no reason and will not come back on. can you...
(More)
mitsubishi tv diamond is broken. it just turned off for no reason and will not come back on. can you help?
when the tv is on every 15 to 45 seconds the TV blinks and it does it every time. i tried resetting...
(More)
when the tv is on every 15 to 45 seconds the TV blinks and it does it every time. i tried resetting it. what else is there? i am not gonna pay a lot of money to get it fixed
