I need to program my remote and need instructions and codes for a Sharp TV
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
WOW I REALLY WAS ABOUT TO GIVE UP AND SURPRISE SURPRISE THERE WAS A CODE FOR MY TDE UNIVERSAL,,,I LOST THE CODE BOOK SO I COULDN'T PROGRAM MY TV,I SEARCHED TDE BUT NO LUCK THEN I DECIDED TO SEARCH THE BRAND OF THE T.V -SHARP I PUT IN 0509 AND IT WORKED YEAAAAAAAAAAAAAAAAAAAAA NO MORE GETTING UP LOLOLOLOL
My sharp tv , model 37EM-33S asks for code number that I have forgoten. Can you help me?
How about codes for huayu rm-36e universal remote
I need sharp tv service code for model 25C-FG8
Sharp tv 2571ntx service code pizzzzzzzzz
Menu and look for remote locator. The code should be in your owner manual.
PLEASE CODES FOR
Sharp DV-3760S . Ta
Can i ask what codes for Sharp Universal Remote Control for the model 29FN1
I need a code for sharp TV model #14LG20 so that I can program my remote
SOURCE: need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
SOURCE: i need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
SOURCE: I need programming instructions for Jensen Remote
Here you go...it took a while but I found the user manual cause I ROCK....that's
right say it with me....He...Rocks...hehe...but anyway here is the link
address if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
SOURCE: One for all remote for Sharp tv
You can go to teh link below. Select your model number from the list. Select the type of device in your case TV then select Sharp then click submit. That will give you your code. You will then see a link for manual. there you can get the insructions for using the codes.
http://www.oneforall-na.com/advanced_search.php
Rca Systemlink3 wont work with sharp tv, I believe I tried everything.
i have a magnavox remote and a sharp tv need codes to make it all work together
HOW DO YOU PROGRAM THE REMOTE WITH THE CODE?
the sharp tv here, model 25h-m60, has been working with a zenith remote, but has stopped turning on and off and switching stations, It still controls volume but that is all...help!
I have an old time warner cable digital remote. My dad programmed it to work with my sharp tv model 13F-M50. I am having the same problem with the channel buttons not working. It does turn the TV on and off and changes volume. I want to know how to program the tv using the old digital cable remote.
How do you program a sharp tv with a jenson remote? what are the steps?
NEED OR A CODE FOR A SHARP T.V. WITH A UNIVERSAL REMOTE...
I cannot get my new Directv DVR romote to accept any of the codes in the manual. I have talked to Directv tecs and they can't make it work...."my tv is just too old" The old one worked fine.
i need remote codes for my sharp tv an i need the codes to use with a rca digital converter box control. all i know about my tv is that it says mts stereo on the front .
i need to program an old style directv remote for my sharp tv
