Question about Car Audio & Video
1994 Chevy cavalier short circuit
I followed standard tests . 1 Disconnect ground at Battery. 2. Connect 12V
test lgt from battery grd terminal to ground wire main- light stayed on a short
circuit indication. 3. Disconnect alternator leads repeat test 2 lgt on alt ok.
4. Pulled all fuses ,one at a time. Performed test 2 light stated on for all
fuses light stayed on. 5. I replaced door switches same result.
    New Friend:
  • 101 Answers
Possible SHORT ON THE CHASSIS.CHECK FOR WIRE TOUCHING CHASSIS,ALSO CHECK THE STARTER CABLE.ALSO CHECK DOOR A DOME LIGHTS,AND ALARM.YOU HAVE AN AFTER MARKET STEREO?
Posted on Feb 01, 2008
  • chris ZAMBROTTA
    chris ZAMBROTTA Feb 11, 2008
    SOME FUSES OR SYSTEMS ARE OR CAN BE TESTED ONLY WHEN IGNITION IS SWITCHED.OR UNSWITCHED FOR THAT MATTER..WHEN YOU TURN YOUR CAR OFF THEIR I STILL POWER TO LIGHTS OR CAR AALARM. WHEN TURN ON SOME SYSTEMS TURN OFF.THAT TEST DOES WORK BUT NOT FOR ALL SYSTETMS. DID U HOOK CAR UP TO COMPUTER?
    MIGHT BE A SENSOR THATS SHORTING. THERE IS NOT FUSES FOR ALL THE SENSORS. UNDERSTAND WAT IM TRU TO EXPLAIN,
Having trouble with all my speakers except my twitters in a 2007 Saturn Outlook...what do I start with? Fuses are good
Speakers get power from the amp if your system has one or from the radio , if the tweeters work it's not a fuse problem . You like listen to your stereo loud . Blew a channel in the radio or amp ?
Take it and have it checked for DTC'S - diagnostic trouble codes
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier (if equipped) have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5 V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3 V AC and slightly higher.
Do you know how to do DC voltage testing ?
Without Amplifier without UK6
Ignition OFF, disconnect the harness connector at the appropriate speaker.
Radio ON, test for 5.0-7.5 V between the signal circuit terminal A and ground.
? If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
? If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
Test for 5.0-7.5 V between the signal circuit terminal B and ground.
If all circuits test normal, replace the speaker.
Dec 25, 2016 | Saturn Outlook Cars & Trucks
How to recode Chevy sunroof. Motion
Circuit/System Description
The sunroof control module supplies each of the sunroof switch signal circuits with a 12-volt reference. When a switch is pressed the signal circuit is pulled low signaling the sunroof open or close request. The module determines the motor direction based on inputs received from the sunroof switch.
Sunroof Motor/Actuator Initialization/Teach Process
Perform the initialization/teach procedure any time:
A new sunroof motor/actuator has been installed.
The existing sunroof motor/actuator has been removed and reinstalled.
The sunroof system has suffered 3 interruptions for emergency events, i.e. anti-pinch, debris in tracks etc., and normal operation is canceled.
By performing the initialization/teach procedure, the sunroof motor/actuator records the open vent stop position. The motor/actuator will then understand the other positions, closed and full open soft stop, and allow express and obstacle detection functions.
  1. Ensure that all electrical harness connectors are connected.
  2. Turn the ignition to ON.
  3. Completely close the sunroof window with the manual close switch.
  4. Press the sunroof vent switch to the vent open position until the sunroof window stops, and continue holding the switch for at least 10 seconds.
  5. Important: The initialization/teach procedure is not complete if the battery and/or ignition power has been interrupted during the process.
    The Initialization/Teach Process must be restarted if the procedure is not carried out completely.
  6. Verify the operation of the sunroof in all positions.
If this does nothing !
Important: Because of the accessibility of the sunroof switch, perform the sunroof switch component test before beginning the Circuit/System Testing.
Power Sunroof Malfunction
  1. Ignition OFF, disconnect the harness connector at the sunroof control module.
  2. Test for less than 5.0 ohm between the ground circuit terminal 2 and ground.
  3. ?‡'
    If greater than the specified range, test the ground circuit for an open/high resistance.
  4. Verify that a test lamp illuminates between the B+ circuit terminal 1 and ground.
  5. ?‡'
    If the test lamp does not illuminate, test the B+ circuit for a short to ground or an open/high resistance. If the circuit tests normal and the B+ circuit fuse is open, replace the fuse and replace the sunroof control module.
  6. Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 5 and ground.
  7. ?‡'
    If the test lamp does not illuminate, test the ignition circuit for an open/high resistance. If the circuit tests normal, refer to Retained Accessory Power (RAP) Malfunction.
  8. Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 6 and ground.
  9. ?‡'
  10. Ignition OFF, connect the harness connector at the sunroof control module.
  11. Disconnect the harness connector at the sunroof switch.
  12. Test for less than 5.0 ohm between the ground circuit terminal 5 and ground.
  13. ?‡'
    Important: Apply ground to the module for no longer than 2 seconds at a time or the module could be damaged.
    When performing the following tests, make sure that the sunroof or sunshade is not at its end of travel position by switching the grounded jumper to the other signal circuit if the sunroof or sunshade does not move in one direction.
  14. Ignition ON, momentarily install a 10-amp fused jumper wire between the signal circuit terminal 6 and ground. The sunroof should move.
  15. ?‡'
    If the sunroof does not move, test the signal circuit for a short to ground, short to voltage or an open/high resistance. If the circuit test is normal, replace the sunroof control module.
  16. Momentarily install a 10-amp fused jumper wire between the signal circuit terminal 4 and ground. The sunroof should move.
  17. ?‡'
  18. With the sunroof in the fully closed position, momentarily install a 10-amp fused jumper wire between the signal circuit terminal 2 and ground. The sunroof should vent open.
  19. ?‡'
    If the sunroof does not vent open, test the signal circuit for a short to ground, short to voltage or an open/high resistance. If the circuit test is normal, replace the sunroof control module.
  20. Momentarily install a 10-amp fused jumper wire between the signal circuit terminal 8 and ground. The sunroof should close.
  21. ?‡'
    If the sunroof does not close, test the signal circuit for a short to ground, short to voltage or an open/high resistance. If the circuit test is normal, replace the sunroof control module.
  22. If all circuits test normal, test or replace the sunroof switch.
Sep 02, 2016 | Chevrolet 2011 Chevrolet Avalanche 1500...
2012 Chevy Silverado low beam light not working.
Regular headlamps or HID ? Check the HDLP LO/HID relay in the under hood fuse / relay box . Will be marked on the inside of the lid . Do you know what a BCM is ? body control module. Could have DTC'S - diagnostic trouble codes stored .
DTC 2575 00: Headlamp Low Beam Control Circuit
  1. Ignition OFF, disconnect the low beam relay.
  2. Ignition ON, verify that a test lamp does not illuminate between the control circuit terminal 87 and ground.
  3. ?‡'
    If the test lamp illuminates, test the control circuit for a short to voltage.
  4. Verify that a test lamp illuminates between the B+ circuit terminal 30 and ground.
  5. ?‡'
  6. Verify that a test lamp illuminates between the B+ circuit terminal 86 and ground.
  7. ?‡'
    If the test lamp does not illuminate, test the B+ circuit for an open/high resistance.
  8. Ignition OFF, disconnect the harness connector at the inoperative low beam headlamp.
  9. Ignition OFF, scan tool OFF, exterior lamps OFF, test for less than 5.0 ohms between the ground circuit terminal B and ground.
  10. ?‡'
  11. Connect the harness connector at the inoperative low beam headlamp.
  12. Connect a 40A fused jumper wire between the B+ circuit terminal 30 and the control circuit terminal 87. Verify the low beam headlamps are activated.
  13. ?‡'
    If the low beam headlamps do not activate, test the control circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the inoperative low beam headlamp.
  14. Connect a test lamp between the B+ circuit terminal 86 and the control circuit terminal 85.
  15. Command the Low Beams ON and OFF with a scan tool. The test lamp should turn ON and OFF when changing between the commanded states.
  16. ?‡'
    If the test lamp is always ON, test the control circuit for a short to ground. If the circuit tests normal, replace the BCM.
    If the test lamp is always OFF, test the control circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the BCM.
  17. If all circuits test normal, test or replace the low beam relay.
May 25, 2016 | Cars & Trucks
My trunk will not open. When I take off battery cable and replace, it opens once. Is there an easy fix? relay etc?
When the rear compartment lid release switch is pushed, the rear compartment lid release signal circuit to the body control module (BCM) is grounded. BCM then grounds the coil side of the trunk release relay through the trunk release relay control circuit. With this voltage is applied to the rear compartment lid release actuator, opening the rear compartment.
Rear Compartment Lid Release Relay
  1. Ignition OFF, disconnect the trunk relay.
  2. Test for 65-90 ohms of resistance between terminals 85 and 86.
  3. ?‡'
    If the resistance is not within the specified range, replace the trunk relay.
  4. Test for infinite resistance between the following terminals:
  5. ?€¢
    30 and 86
    30 and 87
    30 and 85
    85 and 87
    If less than infinite resistance, replace the relay.
  6. Install a 10-amp fused jumper wire between relay terminal 85 and 12 volts. Install a jumper wire between relay terminal 86 and ground. Measure for less than 2 ohms of resistance between terminals 30 and 87.
If greater than 2 ohms, replace the relay.
Rear Compartment Lid Release Relay Malfunction
  2. Verify that a test lamp illuminates between the coil side B+ circuit of the trunk relay and ground.
  3. ?‡'
    If the test lamp does not illuminate, test the B+ circuit for a short to ground or an open/high resistance. If the circuit tests normal and the B+ circuit fuse is open, test the voltage control circuit for a short to ground. If the circuit tests normal, test or replace the trunk relay.
  4. Verify that a test lamp illuminates between the switch side B+ circuit of the trunk relay and ground.
  5. ?‡'
  6. Disconnect the harness connector at the rear compartment lid latch.
  7. Ignition OFF, test for less than 5 ohm of resistance between the rear compartment lid latch ground circuit and ground.
  8. ?‡'
    If greater than the specifed range, test the ground circuit for an open/high resistance.
  9. Connect a test lamp between the trunk release relay control circuit and the coil side B+ circuit of the trunk relay.
  10. Command the trunk release solenoid ON and OFF with a scan tool.
  11. ?‡'
    If the test lamp remains ON all the time, test the control circuit for a short to ground. If the circuit tests normal, replace the BCM.
    If the test lamp remains OFF all the time, test the control circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the BCM.
  12. Connect the harness connector at the rear compartment lid latch.
  13. Connect a 3-amp fused jumper wire between the switch side B+ circuit of the trunk relay and the voltage control circuit of the lid latch. Verify that the lid latch activates.
  14. ?‡'
    If the lid latch does not activate, test the control circuit for an open/high resistance. If the circuit tests normal, test or replace the rear compartment lid latch.
  15. If all circuits test normal, test or replace the trunk relay.
Component Testing
Rear Compartment Lid Release Switch
  1. Ignition OFF, disconnect the harness connector at the rear compartment lid release switch.
  2. Test for infinite resistance between the trunk release switch supply voltage and ground terminals with the switch in the open position.
  3. ?‡'
    If less than infinite resistance, replace the rear compartment lid release switch.
  4. Test for less than 2 ohms of resistance between the trunk release switch supply voltage and ground terminals with the switch in the closed position.
  5. ?‡'
    If greater than 2 ohms, replace the rear compartment lid release switch.
  6. Test for infinite resistance between each terminal and the lid release switch housing/case.
Could be the relay , could be the switch , could be a problem with the BCM !
Apr 17, 2016 | 2007 Pontiac G6 GT Convertible
Fuel door won't open on a 2008 g8 pontiac
Fuel Fill Door Description and Operation
The fuel door latch actuator shares the circuit with the driver door latch assembly. The body control module (BCM), upon receipt of a lock switch lock or unlock signal, will switch the appropriate door lock actuator, as well as a fuel filler door release actuator control circuits to battery positive voltage. The opposing side of the door lock and fuel filler door release actuators is connected to ground by the I/P fuse block through the other door lock actuator control circuit and the doors, along with the fuel filler door release, will lock or unlock as commanded.
  1. Ignition OFF, disconnect the harness connector at the fuel door release actuator.
  2. Test for less than 1 ohm between the control circuit terminal 1 and ground.
  3. ?‡'
    If greater than the specified range, test the control circuit for a short to voltage or an open/high resistance.
  4. Test for less than 1 ohm between the control circuit terminal 2 and ground.
  5. ?‡'
  6. Connect a test lamp between the control circuit terminal 1 and control circuit terminal 2.
  7. Ignition ON, command the doors to LOCK and UNLOCK by using the door lock switch. The test lamp should illuminate while commanding the LOCK and UNLOCK states.
  8. ?‡'
    If the test lamp remains OFF during either command, test either control circuit for a short to ground.
  9. If all circuits test normal, test or replace the fuel door release actuator.
Component Testing
  2. Install a 15A fused jumper wire between the control terminal 1 and 12V. Momentarily install a jumper wire between the control terminal 2 and ground. The fuel door release actuator should perform the LOCK/UNLOCK function.
  3. ?‡'
    If the function does not perform as specified, replace the fuel door release actuator.
  4. Reverse the jumper wires. The fuel door release actuator should perform the UNLOCK/LOCK function.
Remove the rear compartment side trim (right) panel. Refer to
Rear Compartment Side Trim Panel Replacement .
Apr 06, 2016 | Pontiac Cars & Trucks
My rear view mirror camera quit working I checked the fuse it's good the backup lights work.Help
When the transmission is placed into REVERSE, a 12 volt signal is sent to the rearview camera image display module indicating that camera operation is requested. The rearview camera image display module then supplies ignition voltage and ground to the rear vision camera. The rear vision camera sends video information through the rearview camera image display module to the inside rearview mirror through a video signal + and a video signal - circuit. A grounded shielding also wraps the video signal circuits to reduce electronic interference which may degrade the video signal and cause a distorted or otherwise degraded image.
Rearview Camera Image Display Module (UVC)
In the instrument panel behind the driver side knee bolster to the right of the steering column
Do you know how to do electrical testing ?
Rear Vision Camera System Does Not Display
Ignition OFF, disconnect the harness connector at the rear view camera image display module.
Test for less than 1.0 ohm between the ground circuit terminal 3 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 2 and ground.
? If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
Ignition ON, park brake applied, vehicle in REVERSE, verify that a test lamp illuminates between the control circuit terminal 1 and ground.
? If the test lamp does not illuminate, test the control circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the BCM.
Ignition OFF, connect the harness connector at the rear view camera image display module. Disconnect the harness connector at the rearview camera.
Ignition OFF, test for less than 1.0 ohm between the ground circuit terminal B and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
Ignition ON, park brake applied, vehicle in REVERSE, test for 5.8-6.2 volts between the 6-volt reference circuit terminal A and ground.
? If less than the specified range, test the 6-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
? If greater than the specified range, test the 6-volt reference circuit for a short to voltage. If the circuit tests normal, replace the rear view camera image display module.
Test for less then 1 ohm between the shield ground circuit terminal 10 at the rear vision camera display module harness connector and terminal D at the rear vision camera harness connector.
? If greater than the specified range, test the shield ground circuit for an open/high resistance.
Ignition ON, test for less than 1 volt between the signal circuit terminal 9 and ground.
Test for infinite resistance between the signal circuit terminal 9 and ground.
? If not the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the signal circuit terminal 9 at the rear vision camera display module harness connector and terminal C at the rear vision camera harness connector.
? If greater than the specified range, test the signal circuit for an open/high resistance.
Ignition OFF, disconnect the harness connector at the inside rearview mirror.
Ignition ON, test for less than 1 volt between the following signal circuits at the inside rearview mirror harness connector and ground:
• Video + signal circuit terminal 6
• Video - signal circuit terminal 7
Test for infinite resistance between the following signal circuits at the inside rearview mirror harness connector and ground:
? If greater than the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the following signal circuits:
• Signal circuit terminal 12 at the rearview camera image module and terminal 6 at the inside rearview mirror.
• Signal circuit terminal 11 at the rearview camera image module and terminal 7 at the inside rearview mirror.
If all circuits test normal, test or replace the rear vision camera.
Ignition ON, park brake applied, vehicle in REVERSE, verify a clear rear vision image is displayed on the radio.
? If a clear rear vision image is not displayed, test or replace the inside rearview mirror
Feb 21, 2016 | 2009 Hummer H3
My brother in law has a 2003 Chevy Malibu with a 2003 3.4 Impala engine inside. Apparently a previous owner did an engine swap. I check for spark and fuel pressure both are fine. The car still wont start,...
You can confirm each injector is actually working. Get a momentary switch, 2 feet of wire and some spade terminals (or whatever your connectors take). Disconnect the plug that connects to your injectors. Determine which injectors are controlled by which 2 wires. Connect 1 wire to the Positive 12V side of battery, then to one terminal on your switch. Connect a second wire from the other terminal of the switch to one of the two terminals of the injector you are testing, then connect a wire from the second terminal of the injector to any good ground on the car, or back to the Negative 12V on the battery. With the engine off, push the momentary switch on and off you should hear the injector clicking. If you hear the clicking that injector is working. Repeat the procedure for all other injectors. To avoid and shorting issues the wire going to the positive side of the battery should be connected last, and make sure no part of the wiring on the positive side touches any metal during this entire procedure.Disconnect the positive wire after each test to avoid any accidents.
Feb 09, 2015 | 2003 Chevrolet Malibu
I have check engine error codes 11, 12 on my 95 grand cherokee limited the engine wont start just keeps turning over
Code 11 means no distributor reference signal detected during cranking. Check the circuit between the Distributor and PCM (computer). Also, keep in mind the following operations/tests apply to these relays only: Automatic Shutdown (ASD) , Fuel Pump and Ballast Bypass. For operations/tests on all other relays refer to the appropriate test.
OPERATION:
The relay terminal numbers can be found on the bottom of the relay.
Terminal number 30 is connected to battery voltage and can be switched or B + (hot) at all times.
Terminal number 87A is connected (a circuit is formed) to terminal 30 in the de-energized (normally OFF) position.
Terminal number 87 is connected (a circuit is formed) to terminal 30 in the energized (ON) position. Terminal number 87 then supplies battery voltage to the component being operated.
Terminal number 86 is connected to a switched power source.
Terminal number 85 is grounded by the Engine Controller.
TESTING:
Remove relay before testing.
Using an ohmmeter, perform a resistance test between terminals 85 and 86. Resistance value (ohms) should be 75 ±5 ohms for resistor equipped relays.
Connect the ohmmeter between terminals number 87A and 30. Continuity should be present at this time.
Connect the ohmmeter between terminals number 87 and 30. Continuity should not be present at this time.
Use a set of jumper wires (16 gauge or smaller). Connect one jumper wire between terminal number 85 (on the relay) to the ground side (-) of a 12 Volt power source.
Attach the other jumper wire to the positive side (+) of a 12V power source. Do not connect the jumper wire to relay at this time.
CAUTION: Do not allow the ohmmeter to contact terminals 85 or 86 during these tests. Damage to ohmmeter may result.
Attach the other jumper wire (12V +) to terminal number 86. This will activate the relay. Continuity should now be present between terminals number 87 and 30. Continuity should not be present between terminals number 87A and 30.
Disconnect jumper wires from relay and 12 Volt power source.
If continuity or resistance tests did not pass replace relay. The Powertrain Control Module (PCM) and connector are located in the engine compartment, mounted to the inner fender, next to the air cleaner housing (click image fo zoom).
DTC 11 - No reference signal during engine cranking. No camshaft reference signal was detected during engine cranking.
DTC 12 - Battery disconnect. Battery input to PCM disconnected during last 50 key starts.
DTC 42 - ASD relay control circuit. An open or shorted condition detected in the auto shut down relay circuit.
Hope helps.
Jun 06, 2011 | Jeep Grand Cherokee Cars & Trucks
1994 Chevy 4 Dr. 2500 6.5 Diesel start and stall problem
1994 Chevy Truck K 2500 Suburban 4WD V8-393 6.5L DSL
Fuel Cut Solenoid: Testing and Inspection
An inoperative shutdown solenoid can cause a no-start condition. Disconnect solenoid harness connector and with ignition switch in the "ON"
position momentarily touch solenoid harness connector to solenoid connector. If a "click" sound is heard, the solenoid circuit is operating
properly. If "click" is not heard, the system should be diagnosed as follows:
1. With test lamp connected to ground and the ignition switch in the "ON" position, backprobe the shutdown harness connector. If the test lamp
does not light check for open circuit form the ignition switch to the solenoid.
2. If the test lamp lights, check the ground circuit between solenoid stud and injection pump cover to see if connectors are clean and tight. If the
connections are not clean and tight repair and retest.
3. If the ground circuit is "OK", remove the injection pump cover. Connect a jumper wire between solenoid ground connector and ground. With
the ignition switch in the "ON" position, momentarily touch shutdown solenoid harness connector to shutdown solenoid terminal. If solenoid
operates, check for internal injection pump problem.
4. If the solenoid will not operate, replace the shutdown solenoid.
_____________________________________
Fuel Cut Solenoid: Service and Repair
REMOVE OR DISCONNECT:
1. Remove pump cover.
2. Terminal contact nuts.
3. Solenoid.
INSTALL OR CONNECT:
1. Solenoid in the pump cover.
- On the shutdown solenoid, make sure that the linkage is free.
- On the cold advance solenoid, make sure that the plunger is centered so that it will contact the check ball in the fitting.
2. Insulating washers on the terminal studs.
3. Terminal nuts and tighten to 1 Nm (9 in lbs).
4. Pump cover.
5. Inspect solenoid operation prior to installing the pump cover. Use a 12 volt DC power source.
Sep 10, 2009 | 1995 Chevrolet K2500
I have a 2000 Nissan Xterra SE V6. My center
Before you begin to diagnose and test the stop light system (that's what's it's called in the service manual), you should look at the following
wiring diagram to try and understand how the system work. This will help you to logically walk through the diagnosis process.
TESTING FOR “OPENS” IN THE CIRCUIT
Continuity Check Method
The continuity check is used to find an open in the circuit. The
Digital Multimeter (DMM) set on the resistance function will indicate
an open circuit as over limit (no beep tone or no ohms symbol).
Make sure to always start with the DMM at the highest resistance
level.
To help in understanding the diagnosis of open circuits please refer
to the schematic above.
1) Disconnect the battery negative cable.
2) Start at one end of the circuit and work your way to the other
end. (At the fuse block in this example)
3) Connect one probe of the DMM to the fuse block terminal on
the load side.
4) Connect the other probe to the fuse block (power) side of SW1.
Little or no resistance will indicate that portion of the circuit has
good continuity. If there were an open in the circuit, the DMM
would indicate an over limit or infinite resistance condition.
(point A)
5) Connect the probes between SW1 and the relay. Little or no
resistance will indicate that portion of the circuit has good continuity.
If there were an open in the circuit, the DMM would
indicate an over limit or infinite resistance condition. (point B)
6) Connect the probes between the relay and the solenoid. Little
or no resistance will indicate that portion of the circuit has good
continuity. If there were an open in the circuit, the DMM would
indicate an over limit or infinite resistance condition. (point C)
Any circuit can be diagnosed using the approach in the above
example.
Voltage Check Method
to the previous schematic.
In any powered circuit, an open can be found by methodically
checking the system for the presence of voltage. This is done by
switching the DMM to the voltage function.
1) Connect one probe of the DMM to a known good ground.
2) Begin probing at one end of the circuit and work your way to
the other end.
3) With SW1 open, probe at SW1 to check for voltage.
voltage; open is further down the circuit than SW1.
no voltage; open is between fuse block and SW1 (point A).
4) Close SW1 and probe at relay.
voltage; open is further down the circuit than the relay.
no voltage; open is between SW1 and relay (point B).
5) Close the relay and probe at the solenoid.
voltage; open is further down the circuit than the solenoid.
no voltage; open is between relay and solenoid (point C).
Any powered circuit can be diagnosed using the approach in the
above example.
TESTING FOR “SHORTS” IN THE CIRCUIT
To simplify the discussion of shorts in the system please refer to
the schematic below.
Resistance Check Method
1) Disconnect the battery negative cable and remove the blown
fuse.
2) Disconnect all loads (SW1 open, relay disconnected and solenoid
disconnected) powered through the fuse.
3) Connect one probe of the ohmmeter to the load side of the fuse
terminal. Connect the other probe to a known good ground.
4) With SW1 open, check for continuity.
continuity; short is between fuse terminal and SW1 (point A).
no continuity; short is further down the circuit than SW1.
5) Close SW1 and disconnect the relay. Put probes at the load
side of fuse terminal and a known good ground. Then, check
for continuity.
continuity; short is between SW1 and the relay (point B).
no continuity; short is further down the circuit than the relay.
6) Close SW1 and jump the relay contacts with jumper wire. Put
probes at the load side of fuse terminal and a known good
ground. Then, check for continuity.
continuity; short is between relay and solenoid (point C).
no continuity; check solenoid, retrace steps.
1) Remove the blown fuse and disconnect all loads (i.e. SW1
open, relay disconnected and solenoid disconnected) powered
through the fuse.
2) Turn the ignition key to the ON or START position. Verify battery
voltage at the battery + side of the fuse terminal (one lead
on the battery + terminal side of the fuse block and one lead
on a known good ground).
3) With SW1 open and the DMM leads across both fuse
terminals, check for voltage.
voltage; short is between fuse block and SW1 (point A).
no voltage; short is further down the circuit than SW1.
4) With SW1 closed, relay and solenoid disconnected and the
DMM leads across both fuse terminals, check for voltage.
voltage; short is between SW1 and the relay (point B).
GROUND INSPECTION
Ground connections are very important to the proper operation of
electrical and electronic circuits. Ground connections are often
exposed to moisture, dirt and other corrosive elements. The corrosion
(rust) can become an unwanted resistance. This unwanted
resistance can change the way a circuit works.
Electronically controlled circuits are very sensitive to proper
grounding. A loose or corroded ground can drastically affect an
electronically controlled circuit. A poor or corroded ground can easily
affect the circuit. Even when the ground connection looks clean,
there can be a thin film of rust on the surface.
When inspecting a ground connection follow these rules:
1) Remove the ground bolt or screw.
2) Inspect all mating surfaces for tarnish, dirt, rust, etc.
3) Clean as required to assure good contact.
4) Reinstall bolt or screw securely.
5) Inspect for “add-on” accessories which may be interfering with
the ground circuit.
6) If several wires are crimped into one ground eyelet terminal,
check for proper crimps. Make sure all of the wires are clean,
securely fastened and providing a good ground path. If multiple
wires are cased in one eyelet make sure no ground wires have
excess wire insulation.
Apr 06, 2009 | 2000 Nissan Xterra
Car Audio & Video Logo
138 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
