Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remotes don't work (3)
shared by 4 users
posted by KP50 on Jan 01, 2008
One of my garage doors does not open with the remotes, three total. Just started over the past week. No problem with the mounted push button in the garage, except for the fact that the light is blinking continuously?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Posted by Guest on Aug 14, 2008
remotes not working after a gear was replaced hard wire is blinking
remotes do not work hardwire does but its blinking changed batteries in remotes too just had the gear replaced and this just started happening
Posted by dbrowntek on Feb 02, 2008
all remotes do not work how do you find out if the receiving unit is battery operated
Best Solution
posted on Jan 01, 2008
FixYa! (100)
bbtoast
Rank:Guru Guru
Rating: 91%, 204 votes
Did you inadvertantly hit the "vacation lock" button on the Mounted push button? This will cause the remotes not to work. Try hitting the button again, and then see if the blinking goes to solid green.
Good Luck
Comment posted on Jan 01, 2008
Here are instructions for vacation mode:
If you have a three buttom wall panel, one of the small buttons should be the lock button, push this button and hold it for a couple of seconds until the LED on the wall panel stops blinking.
Rating Locked! (?) KP50 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on remotes don't work (3):
I don't want to Accept this solution
Can you Help with these Security Systems and Surveillance problems?
Sears Craftsman LiftMaster Chamberlain...
All of a sudden today the motor for the garage door opener...
I have a Liftmaster 1/2 HP Professional Line chain drive...
what is causing this flashing green light . The door is...
How to correct the problem yourself before replacing...
Have to continue pressing control and eventually it closes...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Find Security Sys. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
