Question about Sharp AR-207 Copier
Sharp SF-1118 copying machine H 4 Error
I have Sharp SF-1118 copying machine
When i press turn on button then apear a message on LED
Flash H then 4 Error
Tell me Solution
  • Anonymous Mar 12, 2014
    Problem with Sharp sf 1025 Copier H 4 code flashing
    Sniper:
  • 54 Answers
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Posted on Jan 01, 2008
I have sharp SF1118 copier now when i press the print button pepaer pass thru the machine but no print appear control pannel is shownig simbel flashin red flower plz help me
Posted on May 14, 2010
2 Suggested Answers
hamzaskilltd
  • 316 Answers
SOURCE: I have Sharp SF-1118 copying machine
heat roller low temperature detection
Posted on Jun 05, 2010
Sharp SF-1118 copying machine H 3 Error
This is a heating error for the fusing section, the lamps may be damaged or there could be a build up of dust and debris on the thermistors that monitor temperature. I would check the fusing section. THIS IS THE UNIT THAT HAS THE TWO ROLLERS THAT THE PAPER PASSES THROUGH AT THE END OF THE PAPER PATH. Check there is nothing jammed or damaged. you may need to replace unit.
Oct 18, 2015 | Sharp Office Equipment & Supplies
Sharp sf 1118 shows error code of red image inform of a person beside or close to the green digital counter . Please I need.a solution thank you.
it means that the machine need service/ to change the P.M kit on the machine and clear the error code by entering the simulation on the machnie
Oct 14, 2015 | Sharp Office Equipment & Supplies
Get error message "Printer error: see your documentation and call service if necessary."
I found this on another website and it worked for me. It apparently resets the printer. Hope it works for you:
1.) power on (error message)
2.) press the "Stop (triangle)" and the "Colour copy" button and hold them
3.) press the power button to power off, still hold 2.)
4.) press the power button to power on, still holding 2.)
5.) the LEDs start to flash, then they stop to flash and the red exclamation mark starts to flash. Now release 2.)
6.) the LED should say: "Init EEprom"
7.) now press and hold the power button until the printer powers off and powers on again.
May 26, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Error message E 7
Try these steps to cancel the error, press the buttons continously
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not, do again step 1 until the display turns off.
STEP3.press 14 then press print button
Jan 29, 2009 | Sharp AL 800 Copier
I need help with my SF-2030 copier
A little rusty on this machine, but try this.
This code means the copier has not warmed up in a specific amount of time.
Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
If it does not reset, you may need to have a tech look at this.
Hope that helps...
Lbcoaster
Jun 28, 2008 | Sharp SF 2020 Copier
MY SHARP AR5316 DISPLAY H4 WHEN I PUT IT ON
Here is the process
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Dec 11, 2007 | Sharp AR-5316 Advanced Digital Imager...
Error CH uppon power up...copy lamp comes on scaner moves forward 2...3 inches shakes and machine stops...
OK, CH normally means the one of the covers(front or side panels) is open or the developer unit is unplugged try these to see if that fixes the problem. p.s When the covers are closed a small tab on the covers triger a interlock switch or optical switch. Hope this helps
Aug 22, 2007 | Sharp AR-160 Copier
Sf-1118
does the same occur when the manual paper feed path is used?
Apr 08, 2007 | Sharp AL 1215 Black and White Copier
Sharp AR-207 Copier Logo
427 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
