Question about Disney DT1900-P 19" TV
NO SOUND The television does not have any sound. We remember when we first received the television it wouldn't play without the DVD player. We have both hooked up but still no sound.
  • conyershelp Jan 01, 2008
    how do you check hte amplifier section or the remote mutting error?
  • 149 Answers
Hi there, no sound means an amplifier section problem, start with the speakers, test the speaker then check the amplifier section, it maybe some jack problem or remote mutting error. ty
Posted on Jan 01, 2008
My surround sound won't work now when I play the dvd player
Could be many things - I know, bad answer. There is no simple answer or fix.
Without more info one can only speculate.
Please determine and answer as many or all of the following so that we can help.
1) What is the make and model number of the Surround sound unit?
2) What is the make and model of the DVD player?
3) How is the DVD player connected to the Surround sound unit?
3a) Is it connected via an HDMI cable?
3b) Does the DVD player have regular stereo connections that you are using (we call these analog audio connectors)?
3c) does the DVD player have digital audio outputs that are connected to the Surround sound receiver?
4) Did the DVD player EVER make sound?
4a) if yes - what changed?
4b) if yes - does this happen with different discs?
Now some general points.
I'll assume that the other sources do work and play sound through all speakers when they are supposed to play sound through all speakers.
Then - I'll assume that without changing anything else you select the DVD player input that used to make sound but doesn't now.
Problem could be the encoding option that you have selected when you play the disc.
Many DVD's and Bluray's have audio options that you can select from the disc's main menu.
Dolby digital is the most common - also known as AC3.
Some discs have another digital audio track called DTS.
Not all surround receivers can decode all formats.
Even if your surround receiver claims to be able to decode AC3 and DTS, they will not if you don't connect the correct cable to the receiver and usually map the input to the correct digital audio connection that you are using OR if your DVD player is not capable of outputting all formats.
There are many different ways to connect the gear and many different ways one can configure correctly or not; all contributing to whether you get sound or not.
So in the above example - by selecting DTS, you do not get any sound - then try another audio track option. Basic stereo usually works (also know as PCM - which is audio like a CD).
OR maybe you never properly configured the audio properties of the DVD player.
Go into the DVD's menu or set up options and see what you find but make sure you know how the DVD is connected to your surround receiver!
As you can see - there is no simple answer without a lengthy Q and A exchange first.
May 26, 2014 | Yamaha Audio Players & Recorders
MY TV ONLY HAS SOUND WHEN IT IS HOOKEDUP TO THE DVD PLAYER AND A SURROND SOUND SPEAKER BUT NOT FROM THE TV OR WHEN HOOKED UP TO THE SPEAKER ON TV OR XBOX
Hi,here is the solution......
Since you successfully connected your
DVD /Receiver to play video on TV (one way only ) ,here is the second reverse action to listen your TV on DVD /Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV ,
** to "TV input "or "AUX input" or "Optic Cable input"
of your DVD /Receiver (whichever you want based on the necessary cables on your hand )
** than just switch to respective mode on
DVD /Receiver corresponding the connector you have used on the back of DVD /Receiver ..
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
There you go..Both Tv and Xbox sound are on the
DVD /Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your DVD /Receiver SURROUNDING SOUND .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 03, 2011 | RCA L46WD22 Television
My component is in LINEAR PCM MODE when it start playing dvd/cd no sound comes out. while in CASSETTE TAPE, it has a sound. i want to know what is this LINEAR PCM, coz i notice, when i turn FM it has a...
LPCM is for digital sources ONLY. Your cassette wouldn't be digital would it? FM, being an internal source on your unidentified receiver CAN'T be wired or configured incorrectly. Crack the manual open and find out how to set the parameters for all the digital inputs, then connect and select an analog input for the tape.
Jun 24, 2011 | Audio Players & Recorders
We have sound on our jvc dvd but no picture weve had this problem before but i cant remember how we fixed it. weve ;put the scarts etc back in and ensured all in order but still not working please helo...
Hello
plug in and tighten the connections on the back of the DVD player, the television and any amplifier, if there's no picture or sound. Plug the DVD player's outputs into the amplifier's inputs. Then plug the amplifier's outputs into the television's inputs. Sometimes the amplifier is called a receiver.
Apr 11, 2011 | JVC XV-S300 DVD Player
No sound while playing a dvd jvc8040b receiver
Make sure the the necessary input of the tv is select to be able to play the sound from your DVD. Also check to make sure you are pluging in the sound cords into the input sound of the tv and not the output. Make sure the source of the tv that you selected to play the DVD through has a sound jack associated with it.
Sep 12, 2009 | JVC RX-8040B Receiver
Overhead DVD monitor screen dead but sound plays through stereo
If it's a Rosen dvd player the dvd will need to be put in the unit itself & not the unit in the dashboard! The dvd player mounted in the head ligning is a seperate unit from the stereo system fitted in your dashboard!
Sounds to me like you are putting a dvd into the dashboard stereo system which will play any audio through the car speakers...
Put a dvd into the Rosen unit itself & i am sure you will get a picture on the drop down screen! Remember that as far as i know all Rosen dvd players transmit the sound from the dvd to infra red headphones that should be included! Remember to check the batteries if you still can't hear any sound as they run down quick if the headphones are left on!
Hope this helps....
Apr 08, 2009 | Rosen A7 Car DVD Player
LG GSA 4163B DVD±RW dvd playing but no sound
Install k-lite codec pack ,you are missing codec. Some recommend vlc player.
Apr 06, 2009 | LG GSA 4163B DVD±RW Dual Layer Burner
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Aug 13, 2008 | Philips PET702 Portable DVD Player
Disney DT1900-P 19" TV Logo
79 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
