Hitachi UltraVision CineForm 55VG825 55 in. HDTV Television
Problem for Hitachi UltraVision CineForm 55VG825 55 in. HDTV...
Tv will not magic focus, there are two curved
By thomascoal25 on Oct 26, 2009
tv will not magic focus, there are two curved sections of blue and green and words are out of focus
Best Solution
posted on Oct 26, 2009
Very Helpful)
SD Tech
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 97%, 1152 votes
55vg825 MODEL DOES NOT HAVE MAGIC FOCUS.
that is a DLP 2005 model.
I am going to make a guess---by the way it is a good idea here to post the actual model number in your description as this saves time and gets you more responses--
If set has magic focus and convergence will not move or is skewed--one or both of the two convergence Ic's this set uses is bad.
Normal life is 5-8 years--a grease to transfer heat from the chips dries out and one overheats and fails.
Most of the Hitachi sets use either 2 STK-392-110 OR 2 STK-392-150 CHIPS---they are the same but the 150 lasts longer.
BOTH chips will need to be replaced if this is the case and any protect resistors around them that are bad also replaced (most of the time just the chips and or 1 resistor need to be replaced.)
Once this is done the set will not have this problem again for 5-8 years.
Depending on your actual model number I may be able to give you general instructions and tell you what you will need if you do the repair yourself.
Keep in mind: usual cost for parts for this repair is about 25 dollars---I can tell you the best place to buy the chips---if you do it yourself there are sites that sell "kits" but for the most part they are much more expensive and most of the parts are not needed.
If you cannot do it shops get 300-400 for this kind of repair---and many will not do it in your home--any good tech can do in home in about 1 hour---I have done hundreds of them 200-250 depending on the set.
Let me know the model number and if you have any questions or need advice reply to this posting here.
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
nettiser
Rank: Wiz  Televisions & Videos  Expert
Rating: 84%, 1639 votes
This is a convergence chip problem and needs technical intervention to unsoloder and replace. There are also some capictors in open citcuit that will also need replacing. Not a DIY. Cost of repair approx $300
\Pleasae rate my help++++Thanks fore using FIXYA
Was this helpful?
Yes
No
Popular Solutions for Hitachi UltraVision CineForm
Questions and Unsolved Problems for Hitachi UltraVision CineForm
Do you recommend Hitachi UltraVision CineForm 55VG825 55 in. HDTV Television?
Answer
Answer
The sound keeps going out. We have no manual to know if we have the sound menu set up right. I would... (More)
Answer
the tv is 5 yrs old and the picture is not in focus. this appears to be mainly at the bottom of the... (More)
Answer
straight lines on the bottom of the screen in Hitachi ultravision tv that is probably 8-10 years... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Surprise, AZ
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
