Question about JVC GR-D20EK Camcorder
Lens Cap Warning & Gray Distorted Display
Had this intermittent problem for the last two years. Camcorder only had a maximum of 3 hrs recording in this time. On powering up the camera whether viewed by LCD screen or lens view finder the camera:
  1. Displays the LENS CAP warning even though the lens cap has been removed prior to bootup.
  2. The camera fails to record an image but does sound.
  3. Only mono grayscale distorted image can be seen on intermittently flickering display.
  4. Playback of previously recorded footage is viewed without problem.
  • 3 more comments
  • dustmat Jan 11, 2008
    hi ive got the same problem can it be fix and how
    thanks
  • Agata Ebbutt Feb 21, 2008
    The some problem with mine, pls let me know how to fix it!!!
  • Anonymous May 27, 2008
    Same problem.........Anyone know of any repair houses around Perth, WA?
  • Anonymous Jul 01, 2008
    i have a similar problem with the same model, my camera keeps telling me i have the lens cap on and if you look through view finder or at the screen it is dark as if the cap was on.
  • Plumber Dave Oct 19, 2008
    I took my GRD 20 EK camcorder on holiday and used it ok.4 hours later it was displaying the lens cap message and displaying a very distorted grey image but recording only the sound. The device has only ever been used for a couple of hours or so.Play back is fine.
  • 3 Answers
CCD Failure/Lens Cap Warning Error JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 30th June 2009 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
Posted on Dec 23, 2008
  • Larry Stiles
    Larry Stiles Jan 24, 2012
    In case this program has expired which I believe it has, I can fix them. The capicitors are fine they need ccd's. contact me at 916-362-8708
    larryselectricsrepair.com
    Larry
  • 156 Answers
TRY TO CHANGE THE CAPACITORS ON THE CCD BOARD ASSUMBLY AND THEN CHECK.
Posted on Jan 01, 2008
No picture from lens; playback ok; lens Cap
CCD (imaging IC) went bad and has to be replaced.
Nov 14, 2009 | JVC GR-D20EK Camcorder
Problem lens cap
I had same problem with my gr-d73aa camcorder and jvc fixed it for free because it was manurefactures fault.
Sep 20, 2009 | JVC GR-D73E Mini DV Digital Camcorder
LENS CAP WARNING
JVC camcorder no picture on screen remove lens cap and unable to record problem is down to a faulty batch of ccd image sensors (thousands that Sony supplied) and if you phone the JVC servce centre (0845 3108000) and explain the problems you are experiencing its a good chance they will repair it free depending on model (I know because I have done just that and JVC are paying for it to be collected, repaired and returned totally free of charge, and mine was purchased in 2004. What have you got to lose the price of a phone call or about £70 to £90 to have it repaired yourself
Good luck syrups6
Mar 24, 2009 | JVC GR-D23 Mini DV Digital Camcorder
Display is black even after removing the lens cap
See my post of before. I just knocked the camera on the floor by mistake and it miraculously started working again after years. Shows it must be mechanical and not related to software.
Jan 28, 2009 | JVC GR-D50 Mini DV Digital Camcorder
Lines through the playback
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Oct 22, 2008 | Canon ZR100 Mini DV Digital Camcorder
Lens cap
CCD Program for This Model - GR-D33US JVC has received reports that in certain circumstances, this model may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at JVC Factory Service Centers. Click this Repair Request link to download a Repair Request Form and find your nearest location.
Please call our Customer Care Center at (800) 858-6442 if you encounter any problems in obtaining a free repair. We apologize for any inconvenience and are appreciative of your understanding and support.
Jun 30, 2008 | JVC GR-D33 MiniDV Digital Camcorder
Jvc video camera
there is a repir thing with certain models see below. CCD Failure/Lens Cap Warning Error JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
May 26, 2008 | JVC GR-D20EK Camcorder
On playback, the video has gray lines across it
Dec 28, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Gray lines on playback
Try using an $8 head cleaner for 10 seconds. That might be the solution or if it's a used tape, the speed isn't limked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that.
Dec 26, 2007 | Canon ZR60 Mini DV Digital Camcorder
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
JVC GR-D20EK Camcorder Logo
522 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
