Question about Durabrand DVD-1002 DVD Player
My dvd player will just not operate. it switches on and says it is preparing, then it will not operate at all
  • 537 Answers
Are you getting this message with or without a disc in it? If it is with a disc, try cleaning the lens with a DVD lens cleaner.
Mike
Posted on Jan 01, 2008
Dvd player says preparing
Mechanical fault. Disc does not loads properly. Contact any service technician. The drive mechanism should be take out to get repaired. Gopakumar Gopalan Google
Feb 26, 2014 | Wharfedale DVD-M3 DVD Player
DVD Recorder door sticks and the disc preparation process does not complete
Try to burn at the lowest speed possible or at one step lower speed that the one you are currently burning at.
Dec 27, 2013 | Dual Presidian DVD Recorder
DVD player frozen
might be there is a fault in DVD. Also try to clean you DVD player's lense.
Dec 18, 2013 | Televison & Video
Power on off button not working
It could be a number of causes including a faulty power supply, the switch itself is broken for whatever reason, or a microprocessor fault preventing it from turning on/off as required.
If the unit does not operate at all even with the remote, then it would likely be a power supply problem, not the switch, which means a workshop repair (if you are prepared to spend a couple of hundred dollars on parts and labour outside warranty) to restore this to full functionality as when it was new, as several parts may have shorted/failed in this circuit.
Samsung has a nasty habit of using unusual rated/valued components in their appliance power supplies, particularly IC regulators, so these are generally not obtainable off the shelf to the public, the only exception being electrolytic capacitors being standard as their values and working voltages can be uprated when replaced.
Feb 26, 2011 | Samsung DVD-R155
After preparing video cd in windows movie maker it cannot be played in my philips dvd player why? i have o/s window vista home edition.tell me the correct solu tion for this problem.
did you "close" or "finalize" the VCD? that's what makes the cd most compatible with all other players. you'd be surprised how many burners don't have that available setting as the "default" setting. also note some of the older, and/or more expensive DVD players have problems with some VCDs. sometimes the newer and cheaper models are more compatible friendly.
Sep 08, 2010 | Microsoft Windows Vista Home Basic Edition
Dvd drawer keeps opening up on its own and will not stay shut?
There is a switch located at the front of the player right under the DVD tray. This switch tells the player that the door is completely closed. If this switch does not operate, then the Ilo will re-open the DVD tray thinking that something is jammed. Might want to try replacing that switch
Dec 29, 2009 | iLO DVDR04
Presidian 3222
I don't know if this will help, but according to the operator's manual I have, on page 64, the only place it mentions "Full" or "Quick" Preparation, is when using a DVD-RW disc. Apparently, with this type of disc, you must use the Full or Quick preparation INSTEAD of Finalizing after you're thru recording onto the disc.
With the DVD-R and DVD+R, all you can do is "Finalize"; With the DVD+RW, if I'm reading this correctly, NIETHER Finalization OR Preparation is required.
But with the DVD-RW, apparently ALL you can do is a "FULL" or "QUICK Preparation.
If you're only getting "Erase or "Finalize" WITH the DVD-RW, then it appears there may be a problem with the machine.
Or, if you're attempting the "FULL or QUICK" Preparation with any disc OTHER than the DVD-RW, all you should get is "erase" or Finalize", since the QUICK or FULL Preparation is not done with discs other than DVD-RWs.
Hope this helps. I'm certainly not an expert on these things....I'm a "Vinyl" type guy.
Roy Davis
May 31, 2008 | Dual Presidian DVD Recorder
Not reading DVD
if your any dvd is not working that mean there would be
most common problem with following thing
1) Try to reinstall your operating system to recover your DVD driver files.
2) change the data cable of the DVD becouse if cable got fault it won't work(data cable on end is connected to dvd and other -to mother board )
3)if still problem is there then you have to change your DVD's Lense.
Nov 16, 2007 | Acer Aspire 1662WLMi Notebook
Durabrand DVD-1002 DVD Player Logo
43 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
