Question about Sony KP-41T25 41" TV
STK output devices PLUS
I have a Sony KP-41T25 and I need to change the STK output devices PLUS. Do you know the part number of this module?
Tks and Happy New Year.
  • 240 Answers
Stk392-150 you need to replace bolth of them.
also for best repair
replace IC301 on (M)board part number 8-752-063-50 part is cxa1477as as a sony part its cost is $60 but the generic part will work fine its only $20.
hope this helps
Posted on Jan 12, 2009
How do I connect my KP-57HW40 57" to my desktop computer
Hello, unless your desktop has a composite (single yellow video output) or a S-video output it won't.....sorry....tks
Nov 01, 2013 | Sony KP-57HW40 57" Rear Projection...
I'm having triple image and a color problem with my Sony color rear video projector modle No.kP-53HS30
Hi,that is come from your convergence module,theres some ic in there call stk wheres they controls the picture linearity but
you will need a technician to fix it...
hope that will help you
regards Alan
Oct 26, 2010 | Sony KP-53S25 53" Rear Projection...
I have a sony kp-41t25 and when i use cable , the screen is like really snowy , but if i hook up a ps2 to the a/v jacks its fine . whats the problem ?
Your TV may have tuner problem. As AV mode is correct, there is no fault in the video section of your tv. Please check the tightness of the cable connection to your TVs socket also. If it is ok, report it to the cable operator and ask them to measure the power strengh of the cable at your home end. If there is sufficiant power strength, replace the tuner of your TV with similar type and number.
Oct 17, 2010 | Sony KP-41T25 41" TV
Hi. On my sony 57in. tv i am getting red arched lines over the entire screen, and double images. 5 years ago i had a similar ocurrence and the tech changed a module. What is the cause ? and why again so...
2 Things can cause this Red Tube needs to be adjust down on screen drive control or you need to replace Both of your STK ICS. Sony has alot of problems with Defective Tubes.Red and Blue Shorted out the most.
Mar 24, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
I have a Sony Model KP-51WS510 Rear Projection TV. My convergence STK need replaced the only parts I could find are STK392-150 (18 prong) when I removed the existing STK parts they are STK392-560 (18...
dont know if they cross or not but do know that (Mat electronics has the stk 392-560 fo 10.50 apc phone number is 1 800 628 1118. just to let you know. Also there is some small fusses that need to be checked to see if any are open they are right under the heat sink where the ic are at and are usly yellow in color 3.5 amp i think plus the restors need to be checked. They should read 1.2 ohms in value there is serivale under the heat sink also. Hope this helps you out.
Dec 05, 2009 | Sony KP-51WS510 51" Rear Projection...
Hi!! my sony projection tv kp-51ws500 shows double picture. there is reddish outline & its out of focus. i need help to reapir this. please advise. thanks
This sounds like a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Sep 30, 2009 | Sony KP-51WS500 51" Rear Projection...
could be anything in the high voltage section of the set going bad caps and bad soldier on fly back can also cause this to happen.
set needs to be checked out by a tech.
Jan 12, 2009 | Sony KP-41T25 41" TV
On the pcb labeled (G) board look for location RY602
the replacment sony part number is # 1-755-018-11
this is the repair for stand by light blinking.
Thi is the repair for Power light blinging.
Q601, Q602 parts number(2sc4843)
r606 0.1ohm 1/2w also replace c604 and c605.
hope this helps,
Jan 03, 2009 | Sony KP-41T25 41" TV
My TV set, an 2004 Sony Model KP- WT510 Rear Projection is having problems with "Convergence" alignment; everything shows double or triple images and picture is totally distorted; I tried to align the...
The convergence output integrated circuits aren't doing their job. These are mounted on a heat sink on the circuit board, but they still get hot enough that sometimes the solder connections to them can break. Resoldering the connections would fix that problem.
It's also possible that the convergence circuit is not getting power, usually be due to failure of one of the outputs, which can cause protective fuses or resistors to blow. This would be harder to repair yourself because it involves determining what parts need to be replaced.
It would probably be worth getting a technician to look at the set and give an estimate for the repair.
Nov 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
STK392-560 you will also likely need two 3.5 Amp pico fuses with the ICs you can get replacments with free instructions at the following link.
Aug 11, 2008 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
