HP Compaq Presario C700T , Pentium Dual-Core Mobile Processor T2390  , 15.4" diagonal WXGA... PC Notebook
Problem for HP Compaq Presario C700T , Pentium Dual-Core Mobile...
My HP presario note book has started to switch off
By saffia786 on Oct 26, 2009
my HP presario C700 note book has started to switch off suddenly in the past 3 days. It only lasts max 1 hour. I think its cause its overheating, i touched the underside of the laptop and it was absolutely scorching. what do i do. I ve also noticed recently that when i plug in my charger, the light at the front of the computer ( small bolt of lightining pic) that lets me know the charger is on, only flashes a moment and then switches off. please could you give me a solution. ( Please can you tell me as simply as possible - im computer illeterate)
Solution #1
posted on Oct 26, 2009
Not Rated)
parrotheadpc
Rank: Guru  HP Computer Hardware  Expert
Rating: 89%, 552 votes
Computer shutting off after a few seconds to a few minutes
This sounds like an auto shut-off signal given by the processor because of a possible over-heating issue. This usually happens when the laptop has been run for an extended time without having the dust, dirt and debris cleaned from its cooling vents and grills. After time, the thermal paste on the processor bakes under the extreme heat and starts to flake off and lose its efficiency at cooling the processor.
Get a few cans of compressed air that you would buy at an office supply store and using short bursts, blow out the dust and dirt from all the ventilation grills and vents first, make sure the laptop is powered down and battery removed. Then, open all the compartments and clean them out as well including the cd/dvd tray. There is a small black hole on the dvd bezel, just stick an open paperclip in it and it will pop the tray open. Blow a good blast in there to clean the dvd player.
There is the possibility that the thermal paste will have to be replaced, that means you need to gain access to the heatsink and remove from the processor, clean all the old thermal paste from it and apply a small thin layer of new paste to the top of the processor and replace the heatsink, securing it evenly with the attached screws. If you uncomfortable with this step, I would look into one of the local shops to perfrom this procedure for you, because it is critical for the laptop's survival over the long run.
Was this helpful?
Yes
No
Popular Solutions for HP Compaq Presario C700T ,
Questions and Unsolved Problems for HP Compaq Presario C700T ,
Do you recommend HP Compaq Presario C700T , Pentium Dual-Core Mobile Processor T2390 , 15.4" diagonal WXGA... PC Notebook?
Answer
Answer
how can i fix my mouepad
Answer
D drive will not work. laptop will not recognize that a dvd or cd is in the drive
Answer
wireless broadband wont display a web page but is connected.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Compaq Presario C700T ,...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
