Question about OKI C5200n Laser Printer
Repeated paper jam in fuser
I was printing business cards using Avery's Clean Edge Business card 5871 stock when one sheet jammed at the fuser. Because the cards are meant to separate, the sheet fell apart, and I had to pull severl pieces out. After I had taken out all the pieces I could find, I esumed printing, but again had a jam at the same point. I tried a couple more times using plain paper, and got the same result at the same point every time. I noticed also that there seemed to be a wrinkling at a small section ofthe fuser. Thanks for any help you can send my way.
  • 2 more comments
  • poyan Jan 05, 2008
    I replaced the fuser last night with a new one, but got another paper jam. I haven't tried printing again, didn't want to damage this new one. Thank you all for your responses.Please keep 'em coming. At this point, I'm now thinking of getting a different brand printer, but Im going to get stuck with a new fuser and unused toners. I'm willing to give it one more sot. Does anybody have any info on how I can look at the point before the paper gets to the fuser? That may be where the jam starts. Thanks very much again!
    Regular paper gets jammed, too. I tried 20 lb weight paper thinking the card stock weight was too thick, but it got jammed just the same. Just background info, I've done over 500 business cards of the same brand and type before without any problems. Thanks again for the latest tip. Don't be shy about giving me more! It's much appreciated!
    Exact location of jam on a single sheet is?? Fuser
    Are you using bypass and face up tray??? Yes
    print out a status page via printer keypad does it occur then too (think its online held done for 5 secs)???? Yes
    The paper ends up folded like an accordion.Please see the attached photos. Thanks again for your help!
  • poyan Jan 06, 2008
    Printer's up! Soulvisitor's diagram helped me locate the jamming point. Rollers at 16, 17, 23 had been inverted, probably when I was reaching for the jammed cards. Thanks very much, Soulvisitor, your'e the person! and all the others who pitched in during my time of need! Hope I can return the favor someday.
  • OKI Master
  • 1,113 Answers
Fuser's orange roller is not meant to be wrinkled, if this is then I would recommend you replace it (just slides out) pic below
Repeated paper jam in fuser - b4eead5.jpg If printing on card, you need to feed via manual bypass and exit from the back, not on the top, aka the "face up tray." Tray pulls out from rear. Rear tray will only stack a few card sheets at once.
Setting on printer's control panel must be set to card/heavy paper type on manual bypass tray
Their may still be some card in fuser causing jams.
Please rate as FIxya or post back,
S. :-)
Posted on Jan 02, 2008
  • 4 more comments
  • Soulvisitor
    Soulvisitor Jan 05, 2008
    please confirm paper type is set to card on keyboard of printer and you are using bypass to feed and face up tray for exit.
    maxium paper weight is 203 gsm so ensure card stock is not heavier than this, does it feed normal paper ok?
  • Soulvisitor
    Very important to know if when just a single sheet is printed if it gets jams, ie not printing two sheets, because if we are talking of a jam that occurs only when printing multipull sheets but not on a single.
    We speak in different tounges I speak grams and you pounds.But no matter if you have tried normal weight paper. Here its 80gsm so maybe thats 20 lb
  • Soulvisitor
    This is so typical of a fuser fault, but you have changed it, so it must be set of rollers after the fuser aint turning, check that set of rollers on lid are connecting exit rollers when lid is closed
    above:-Area A is where I'd be looking, the bits I marked with o is check gears in that area, for missing teeth. Please note tray marked 35 is the face up exit tray.
    somewhere on above unit is the problem, rollers marked 16 and 17 I have seen not connect to a set of rollers on lid causing issue like yours, also check 20,19,18 for free movement.
  • Soulvisitor
    should read tray marked 36 not 35
    pic 2 is a closeup of pic 1
  • Soulvisitor
    Check area behind fuser for smooth switch operation
  • Soulvisitor
    Soulvisitor Jan 06, 2008
    Great to hear!
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Jammed card stock
This machine has auto paper type sensor- may be at fault
May 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
Printing on business card stock
goto avery website and download designpro for free it has all the templates for avery stationary
Mar 18, 2009 | Lexmark X6570 InkJet Printer
Printer problem
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Office Equipment & Supplies
Trouble printing Clean Edge business cards
not tru. you need to go to printer set up and chane the setting to heavy paper so that the fuser will fuse the toner in to the card stock
Dec 03, 2008 | Brother MFC-465CN InkJet Printer
Printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
May 20, 2008 | Brother HL-2040 Laser Printer
Problem printing business cards
in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
Mar 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Paper jam
Hi Carylw,
Open the back door ,
be carfull to pull the paper in the same direction
also be carfull not harm the fuser foil
Oct 22, 2007 | HP Laser Jet 1320 Printer
Only prints business cards correctly on plain paper, but not on the card stock.
I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
Oct 21, 2007 | HP PSC 1410v All-in-One Printer
OKI C5200n Laser Printer Logo
606 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
