You may need a new spark plug or ogniter depending on when it was build.Also check the fuel line prom the pump for leak.If none of these check the fuel filter in the tank.
I have a Reddy heater 3500 that was given to me. I have no idea as to the technical aspects of this...
(More)
I have a Reddy heater 3500 that was given to me. I have no idea as to the technical aspects of this heater. I do know that when you push the ignition switch all you get is a few clicks, no ignition.
The heater starts fine, but the gas flow is significantly reduced after a few seconds. Tried a...
(More)
The heater starts fine, but the gas flow is significantly reduced after a few seconds. Tried a different regulator but the same thing happens. Unit ran fine for almost a year, then without warning this gas flow problem occurred
