Question about Irons
Faulty Russell Hobbs Steam Iron
After several months of problem free use, the iron will not now pass hot water from the base unit to the iron.... Have changed filter, but still no joy
  • 1 more comment
  • Tony R Jan 03, 2008
    It appears that the pump is tyring to pass water, from the main unit, when the steam trigger - on iron - is pressed.... But no steam is ejected..
  • amanda
    amanda Apr 13, 2012
    mine is doing exactly the same. every time the water starts to pump through the base unit it starts leaking all over my floor (from underneath the water resevoir). think i'm going to give russel hobbs a call. it seems everything i buy from argos breaks down...anybody else notice this ?
  • Anonymous Mar 27, 2014
    when using the water is coming from the base unit and leaking on the floor
  • 138 Answers
I think the pump inside the Iron needs to be changed! try it it may help you!
Posted on Jan 03, 2008
  • 790 Answers
  • Kanth raj
    Kanth raj Jan 01, 2008
  • Kanth raj
    Kanth raj Jan 03, 2008
    • Follow
      the manufacturer's instructions to keep the steam vents from becoming
      clogged. Some irons use tap water; others require distilled water.
    • When
      you clean the soleplate of your iron, remove residue from the vents
      with a cotton swab or pipe cleaner. A sharp knife or other tool may
      scratch the soleplate
    to Clean Water Reservoirs
    Remove mineral deposits from the water reservoir . Pour a solution of 1/3 cup white vinegar and 1/3 cup
    water into the water reservoir. Heat the iron, and let it steam for
    about three minutes. Unplug the iron, and position it, soleplate down,
    on a small glass dish that has been placed in a larger shallow pan.
    Allow the water to drain from the vents for about an hour. Drain away
    any remaining solution, and flush the reservoir with clear water before
    using the iron.
I have a Russell Hobbs easyfill 2400W Iron. Water is running out the base of the iron. How can this be rectified?
take it in to an appliance repair shop
generally it is cheaper to junk it and get a better quality unit
Dec 21, 2017 | Russell Hobbs Irons
My Iron heats up but no steam comes out and no noise please help !! Russell Hobbs steam 2200
If the water used is hard it will build up with shale, and block the steam vents, best to flush with clean water after every second use . Best to take to the dealer and have it serviced .
Jul 10, 2015 | Russell Hobbs Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
Brown water and seems like sand or fine grit comes from iron ,when first put on with the steam
sounds like it is time to de-scale the iron to loosen all the deposits inside the unit.
add some white viegar to the water ( which should be distilled water ) and heat up and let the iron steam out the solution. now add just water to the unit shake it and rinse out with water and drain. now do one more vinegar / water de-scaling and rinse out again. now fill with just distilled water and let it steam out and now your iron should be clean as new.
Feb 12, 2011 | Russell Hobbs 13153 Iron
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
Russell Hobbs Steamglide 2200.Iron and steam station seem to be heating correctly, but will not dispense steam when trigger on iron pressed.
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Aug 10, 2009 | Irons
No steam from russell hobbs steam glider iron. replaced filter
its due to not getting appropriate required current to the main board of the unit.also check out any thing got loose on the board .first off all try doing dry /cold solder to whole board it should work if not then check out for the proper current flowing through the resistors mostly 1 of them may be definately faulty and needs replacement. thanks.
Jan 04, 2009 | Applica Steam N Glide WSI750 Iron
Irons Logo
585 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
