Question about Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer
Hoover Ultracare 1600 - Dryer not working
The dryer on my all in one isn't getting hot enough to dry the clothes. I have taken the top off the machine in pressed the reset button (which clicked), the dryer is now working but still isn't getting very hot.
Please can you help?
Thanks Lindsay.
    Problem Solver:
Check the duct work see if it is clogged up with lint.  Everything you read tells you to clean it out, but how many of us do it?  I just had the same problem with my duet dryer and when I went under the house to check, the duct was clogged up with lint and works like a charm now.
Posted on Jan 01, 2008
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Hoover 5040ed clothes dryer does not heat up enough to dry clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 02, 2011 | Hoover Dryers
Does not seem to get hot enough, and takes too long to dry clothes. A new heating element has been put in and a couple of sensors.
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 29, 2010 | Maytag Dryers
I have a ge profile gas dryer. It never seems to get hot enough to dry clothes the first cycle. Even if it's an hour and twenty minutes long. Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 19, 2010 | GE Dryers
Dryer does not get hot enough to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | GE DBXR463EDWW Electric Dryer
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
Dryer gets hot but doesn't dry well
Restricted air flow...either vent or wheel that moves the air. Try taking hose off of where it goes outside and just let it run like that and see if clothes dry faster. If so you need vent cleaned.
Oct 06, 2017 | Hoover HWF5513E Front Load
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer not heating Enough
Ceck the vent hose and vent. Make sure these are clear of obstruction. This is tipical of poor venting. The dryer can`t remove the moist air to dry the clothes properly.
Nov 14, 2008 | Hoover HDC6 Electric Dryer
Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer Logo
791 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
