Ghosting Having picture quality problems with my Samsung 37" lcd tv. The set is only 6 months old. the picture appears to be "ghosting" and is worse when there is any movement on screen Doesn,t have to be an action scene. Any help would be appreciated. Thanks.
  • 149 Answers
Hi there, see the micro switches, do some test and look for some cold solder at the board of the unit. ty
Posted on Jan 01, 2008
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
May 24, 2010 | Sanyo DP46849 46 in. HDTV
Ghosting
a lot of these set have auto focus which may just need to be run through the menu or setup on the remote. Are you using a cable box or antenna? this can make a difference as well.
May 04, 2010 | LG 47LH55 47 in. LCD HDTV
Hey, i have a samsung ln32b360, just 2 months old. worked beautifully when i got it, but recently it started ghosting a little in very specific situations. then it started ghosting a lot, but only in dark...
First,If there are double images or "ghost" images on the TV's picture, check the cable connections and make sure they are secure.Because the loose cable connection would be a chance for the ghost picture
But if the cable is perfect and if you still get ghost picture then here is the solution:
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Its best to avil warranty and change the panel...
Please leave me comment, if you need furher assitance
Rnj VINODKUMAR
Oct 27, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Ghosting problems with a Samsung-LN32B360
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
May 25, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Pixelated lcd tv picture
it indicates that the problem is aspect ratio or pixel settings for thescreen
bring up the on screen menu and adjust the pixel setting to fit the screen or the apsect ratio to fit the screen
read the operators manual to see how the adjustments are made
May 19, 2017 | Sylvania LC370SL8 37 in. LCD Television
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
