Question about Acer TravelMate 240 Notebook
Backlight faliure travelmate 240 the backlight has failed on the laptop above. i have been able to strip out the lcd screen from the loptop casing/surround, but was unable to see an obvious bulb to change. is this locatedinside the screen, behind the white plastic backing? and is this a reasonably easy job to do???
  • lady breeze Jan 09, 2008
    Pc world advised that the bulbs are around $10.00 (available from net), but it would cost £160 to have it sent off to a service centre for it to be replaced!
    So it must be poss to change the fluro backlights inside the screen itself, as aposed to replacing the whole LCD?
    OR.... does anyone know of a company that maybe does re-conditioned screens, old for new????
  • lady breeze Jan 12, 2008
    does anybody know?
Thank you for the link, however i already have that file. it is very usefull but does not explain or go into any detail about the BACKLIGHTS on the LCD
i have the screen out and striped as much as that info doc can tell me....... but where are the BACKLIGHT LAMPS??????
Posted on Jan 10, 2008
  • 81 Answers
Its a florescent backlight and is an integral part of the LCD screen.
You need to replace the entore screen, not just the backlight.
I hate to tell you this, but unless you can find a screen on E-bay or similar site it is going to cost you almost as much as a new computer.
You can buy a used travelmate 240 for around $200 and drop yyour hard drive into it and be up and running as before in a matter of minutes. Then you may be able to sell the old one as a working base with a bad screen to recoup some of what you paid out.
Good luck.
Posted on Jan 06, 2008
ACER TRAVELMATE 5730 DISPLAY
get recharge the LCD from service center.
Apr 29, 2014 | Computers & Internet
My Acer 240 screen won't work it appears to be working otherwise
Connect a monitor to the video output, if picture is okay the problem is in the inverter board located under the laptop screen, or the backlight has failed, now if the monitor shows the same symptoms the problem is in the video card ic.
Sep 02, 2012 | Acer TravelMate 240 Notebook
Fade display problem
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 10, 2010 | Acer TravelMate 2300 Notebook
Why would my HP laptop screen go black?
A few reasons
1) backlight burnt out (or broken)
2) loose or broken cable AND backlight burnt out (or broken)
3) Failed GPU (probably integrated into the motherboard on that model)
4) failed motherboard (same issue above)
Check by plugging in an external monitor- if you get a signal, your LCD need a new backlight (or inverter, an easy fix under $15 USD)).
Cheapest solution is to simply replace the backlight, but you'll have to diassemble the entire laptop lid/cover AND the LCD to get to the backlight at the bottom. (this could be under $20 USD to do). Often similar sized LCD's with different part numbers will work fine in different laptops (meaning, a 14" LCD mady by samsung or LG will be compatible with almost any same 14" LCD made by either, especially if it comes WITH the inverter!)...
:D
Sep 04, 2010 | HP Pavilion dv2000t Notebook
Backlight very low making screen dark
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 29, 2009 | Acer TravelMate 4200 Notebook
Acer TravelMate 230LC PC Notebook, lcd screen does nothing just black the power light comes on thats it what could it be
Shine a flashlight at the screen, if you can faintly see the image then your backlight has failed and you will have to contact acer to have it replaced.
Oct 04, 2009 | Acer TravelMate 2300 Notebook
When i switch on my laptop it does not display anything on the screen but it is on? why
does it sound like it boots up? if yes problem with the LCD screen. does the LCD lit up? if no problem with the inverter or lamp.
Jul 07, 2009 | Acer TravelMate 240 Notebook
ACER 4100 TRAVELMATE
If this happened suddenly, the backlight power supply (inverter)  has probably failed. It could be the backlight itself but they normally will dim or flicker before they die.
Try shining a light at an angle on the display with the computer turned on and look at it from an angle too. You may be able to see video very faintly; if you do, then it is as described above; a backlight problem, not the LCD display itself.
Jan 22, 2009 | Acer TravelMate 4100 Notebook
Acer TravelMate 240 Notebook Logo
124 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
