Dell 924 All-in-One InkJet Printer Logo
Posted on Oct 26, 2009
Dell photo 924 is completely unresponsive. Power
Dell photo 924 is completely unresponsive. Power light is on but won't go off except by unpluging. No response to any button. cartridges don't center when carriage is open, etc. Driver is installed correctly, plugged/unpluged power and usb cable several times, rebooted computer, nothing. Any thoughts?
  • jim0952 Oct 26, 2009
    Thank you for responding so quickly.
Josh Stingel
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Oct 26, 2009
Josh Stingel
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
11957
Points
90
Pitch it. There does not appear to be a firmware update. That would be the only thing that would have a chance of fixing this. Otherwise, the controller board is shot. The cost of repair is more than the printer, buy a new one.
1helpful
Dell Photo 924 set-up completed; exclamation light on
Thats why it will not work, it MUST have cartridges in all slots or it throws up an error and will not work... usually there are inks with the printer, are you sure they aren't in the packaging somewhere? Even if only sample ones? In any event, you are going to have to fit them.
2answers
Dell Photo AIO Printer 924 - Printer Busy
Might need a new printer. Lexmark printers can be troublesome.
I do not have the installation disk for the Dell AIO 924
Click here to open the drivers download page for your printer.
Chose the right windows version in the box on web page above.
After download is complete install drivers.
Start driver installation with printer USB unplugged.
1helpful
Scanner won't work on Dell 924
Same thing happened to me, only different model.
First, make sure you have the right drivers (and by that I mean 32-bit or 64-bit).
Go to control panel and remove your previous installation; reboot; reload the drivers with your All-In-One UNPLUGGED until they tell you to plug it in.
That was the trick that worked for me. Good Luck.
Dell photo 924 - scanner does not work
select the scan problems in the below mentioned guide , it would take you to the solution, if its a software fault.There is nothing much we can do if the scanner bed is faulty except for getting the printer replaced if under warranty
http://tinyurl.com/5nua8k
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
