GE washer is leaking water from underneath the front of the machine. What could be the cause? Also, the rubber liner of the door opening has a hole in it from wear, could this be causing the leak?
Horrible agitation. I can't even wash bath mats or anything heavy and large. Have had it checked by...
(More)
Horrible agitation. I can't even wash bath mats or anything heavy and large. Have had it checked by GE repairman and he just checked for balance. Had level platforms built to try and help with balancing. Gets off balance with each wash. The machine is on a pedastal. Had checked to make sure shipping bolts were removed and they were. Hate this machine
Water pours out from under the machine at initial fill. I can see it coming from the little valve...
(More)
Water pours out from under the machine at initial fill. I can see it coming from the little valve inside above the door....not necessarily the main fill valve on the left.From underneath I can see it running down the counterweight in the front of the machine. This is not a small leak, it runs out on to the floor as fast as it is filling.
