Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Pump continues to run
This is a sgs43c02gb(on tag at rear
classiXX maXX freedom dishwasher
on any setting (4 push buttons on front) does the job but will not switch off drain pump until you either open door or switch off ,but once door opened or switched of you can close door and its ok ,this is a intermittant fault, getting worse
  • 1 more comment
  • gadgetfreek Jan 01, 2008
    what does the reset do
  • Daicatering Jan 02, 2008
    My drain pump on this machine will also continue to run for hours, but its intermittent. It can also get stuck in the main wash cycle sometimes. These faults are the worse kind; problem free for 2 weeks then up it pops again. Sticking relay on PCB?
  • Nick Lynch Feb 13, 2008
    I have the same problem and so, apparently, have many others. I've checked the flood safety thing (styropore float switch in the botton) and its definitely not that. Does anybody know how the machine determines when its actually empty? I can't see another float switch anywhere.
My dishwasher now seems to be OK after playing up for 4 months. It now goes through its cycle perfectly. It seems to me to be the float sensor / switch thats at fault by being slightly blocked and therefore not being sensitive enough. Chuck plenty of water around the sump, clear out and clean around all the holes very carefully with a flexible piece of wire and put the machine through the shortest cycle many times. That seems to have worked for me!
Posted on Mar 17, 2008
Pcbs are detecting a fault that is not there,not good for bosch used to very reliable.
Posted on Mar 16, 2008
  • 90 Answers
Make sure you dont have water sitting under dishwasher in tray. it can cause pump only to run. If there is water in bottom, look under water valve, there is a float-is it surrounded with water?
Posted on Jan 05, 2008
Why does my bosch classixx maxx freedom performance dishwasher not heat the water
I would suspect the heating element have failed , calling a service repairman might be your best recourse .
Jun 08, 2016 | Bosch Dishwashers
Bosch classixx dishwasher starts cycle then says " check water" and then seems to do same thing again and again, pumping water in and draining it again
Probably jug impellor part number (424099) from espares, buyspares or bosch direct.
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left (white plastic disc with two wire connection tag). Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Mar 09, 2013 | Bosch 24 in. SGS43C12 Classixx...
Hi I have an Bosch SGs43c02gb/35 and it does not drain all of the water out when it has finished the cycle, I have cleaned the filters out which were relatively clean and run it with a dish washer cleaner...
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Aug 20, 2011 | Bosch 24 in. SGS43C12 Classixx...
Water will not drain from my bosch classixx maxx freedom dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
Aug 14, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Dishwasher Maxx classixx Model S9H1B Lights stuck on end and last program.... will not reset nor start Think it just needs resetting ...but how?? Was working fine up to now Regards M
look carefully at operating buttons they will have 2 marked with a line with dots at either end, open door press and hold these 2 buttons usually 2 and 4 as from left too right, turn on keeping fingers on these buttons after a few seconds end light will come on turn off at main switch then back on again should work after that.
Nov 10, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Water not draining from the machine
If it IS the pump, it’s often because some relatively minor item (piece of cocktail stick/bit of nutshell/etc) has found its way past the filters and is blocking the blades of the pump. It is relatively simple to remove the inlet hose to the pump and clear the blockage (a pair of grips to pinch and remove the retaining clip, then the hose will slide off the fitting on the pump). I did this several times on my previous (Hotpoint) machine – and suspect it is no harder on the Bosch (which I now have). If that doesn’t work, you are half-way to replacing the pump, which is not a difficult DIY job and I’m surprised any competent professional repair man wanted to write off a machine where the pump had failed. A new pump should cost around £40-£50 – less than a quarter of the cost of a new machine. DIY fitting would maybe take a couple of hours; a pro ought to do it in less than an hour.
Mar 08, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher sgs43c02gb cycle problem.
I found the problem for pump noise & water in bottom. The dishwasher hose connection under sink had small plastic piece stuck in narrow elbow
Jan 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
430 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
