Question about Casio Exilim Card EX-S100 Digital Camera
Pushed in the lens and now when i turn it on it wont come out. i opened the camera to see if i could fix it. it came out by forcing it manually. still when i press on button, the small motor goes on but the lens doesnt work
SOURCE:
SOURCE: will not come on
try taking the memory card out and then powering the camera on and off
Posted on Nov 18, 2007
t00nz
  • 4738 Answers
SOURCE: Stuck Camera Lens
Know this is an old post but this might help others with the same problem. The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
MNfisherman
  • 11896 Answers
SOURCE: battery charged, however camera will not stay on
This is a firmware problem that is very common in newer electronical devices especially cameras. You may get lucky enough to find an upgrade program online, but most chances are that you will have to send the camera in to the manufacture and they will repair it for $50
Posted on Aug 05, 2009
VinayT
  • 1884 Answers
SOURCE: When I press the on button, the lens comes out,
May be some dust particles have gone in the lens well between the body and the lens casing. Try to **** it out with the vacuum cleaner.
Posted on Aug 08, 2009
  • 16 Answers
SOURCE: Casio EX-Z55 wont turn on after lens error
what i did for this was, remove the memory card, charge the battery fully, once fully charged, hold the on button and push very lightly down on the lens. had to do it twice to get it right for me. once it was fully in i shut it off and pulled the battery out for a few minutes.
do not push the lens in to hard, it will crack or get out of alignment.
hope this helped it fixed it for me
Posted on Aug 30, 2009
My samsung pl100 wont turn on. the lens is extended and its fully charged the green light comes on then beeps and shuts off. This camera is brand new ive only had it 1 week! how do i fix it?
OK this might sound harsh but i just did this. I pushed in, gently with some force, on the lens while pushing the power button. It made a gawd awful crunch sound, but it worked. Good luck.
Dec 23, 2010 | Samsung SL202 Digital Camera
The screen says lens error n wont let me take pictures or thathow can i fix it
if your lens has an opening protector on it, open it manually (if possible. dont force it open and break it) and see if there is a break in it. if there is a break, you might have to find a new camera.
hope i helped..
Jul 30, 2009 | Kodak Easyshare M753 Digital Camera
Lens wont retract
When the lens will not retract and camera is not functional (no picture ondisplay, and does not shoot) , and you already tried replacingbatteries with a new fresh set (ensure please) , and then restartingcamera with no memory card inside, then camera is faulty.
Try aneasy fix by pushing gently the lens (do not force them, just help them)while you turn off camera at same time. Try also switching the modeselector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair frommanufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Feb 18, 2009 | Sony Cyber-Shot DSC-S85 Digital Camera
My camera keeps on saying lens error and it wont turn off or on.
the lens error is usually a sign that the opening mechanism failed .
try to reset it manually (push VERY SLOW on the lens cilinder to help it close)
if it is an expensive camera you can send it to the manufacturer for repairs as a better and safer
solution.
Sep 14, 2008 | Cameras
I droped my camera on the grond and it wont turn on.it fell the side of the lens
Theres a very good chance you are going to have it repaired by a Camera Repair person. I would really need to know the brand and model.
If it is a canon then it will most def. need a new lens assembly. they have metal pins which guide the lens and when they are droped the pins break out of place.
If it is a Nikon or Sony or Casio alot of times I have been able to push the lens straight and it will re-align itself and work perfect again. But that said I wouldnt be too forceful unless the camera is not worth fixing. In that case you really arnt risking anything other than the possibility of fixing it.
Jun 26, 2008 | Olympus Cameras
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Buzzing sound, wont come on!
Don't try and manually push in the lens at first...the buzzing is a warning letting you know that something is wrong with the camera. By accidently removing the batteries during shut down you interupted the shut down sequence. Try and turn on the camera and immediately press the play button on the back. This should reset the camera. If not and if you are under warranty it needs to be serviced. If you are not under warranty then you can try and push the lens down. Don't use a lot of force but try and gently do it.
Jun 09, 2008 | Cameras
Kodak Easy Share Z1275 stuck lens
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
Jun 05, 2008 | Kodak EasyShare Z1275 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Cannon Power shot SD630 Lens Problem
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Sep 30, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Casio Exilim Card EX-S100 Digital Camera Logo
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
