water was leaking from underneath machine.I checked connections all good no leaks{hot and cold and...
(More)
water was leaking from underneath machine.I checked connections all good no leaks{hot and cold and overflow}I turned washer on to listen to it,iy sounded like water was leaking from inside somewhere.its the front load Kenmore Neptune series.I also looked inside front door there is a hole at very bottom of the rubber catch section,right below front part of inner bowl{the part that spins}
water on the floor, more and more. Is there a filter to clean? Or does the outgoing water line get...
(More)
water on the floor, more and more. Is there a filter to clean? Or does the outgoing water line get plugged with lint?
Maytag Neptune Washer MAH5500B electronic display panel is dead and the front door won't open....
(More)
Maytag Neptune Washer MAH5500B electronic display panel is dead and the front door won't open. Cannot do anything with the washer. Please advise how to fix. Thanks in advance.
