Question about Compaq Evo N610C Notebook
Powered off. I booted my Compaq Evo N610C Notebook. After about 5 minutes, while the battery was fully charged at 100%, the screen went off. After that, I kept on trying to power it on. Nothing seems to work. There are no lights, and it is not booting up with both the power cord and without it.
    President:
  • 4,402 Answers
Any beeps when you turn it on? unplug everything and then plug it back in. Make sure the monitor connections are good and that you have it turned on. Again make sure it's turned on. Sometimes it's the simple stuff. Was the monitor working well before it failed? Do you have a video card?
Remove the battery, AC, count to ten and try one last time?
Posted on Jan 03, 2008
Where is the coms battery for compaq evo n610c located
hi,
If your in the need to replace your cmos backup battery on your Compaq Evo N610c, N610v, N620c Series Notebook help might be just around the corner and thru the usage of this guide familiarize you with what you will need to solve the error prompts flashing on the screen regarding corrupt cmos. At this point you have come to realize that the notebook is no longer booting your Operating System should that be Microsoft or Linux OS's.
The first thing you will need to be familiar with, is where the cmos backup battery is located on your notebook. You can start by turning over the notebook to the bottom side and adjacent to the Main Battery will be a small rectangular compartment held down by two screws (Mini PCI Compartment Cover).
db96_2.jpg These two Phillips head screws must be removed in order to expose the cmos battery that's held in place by a battery holder.
db99_2.jpgThe battery holder accomidates the BR1225 Lithium 3 volt battery, allowing the two potentials of the battery to maintain power to the cmos chip and therefore sustaining the clock/date settings as well as the boot sequence set by the end user. These non rechargeable lithium batteries provide operational function while the notebook is powered off.
After having identified the location of the cmos battery, and having removed the two screws that hold the black rectangular plastic cover, use a non magnetic/plastic tweezer or equivalent probe and pry out the BR1225 battery retained in the Battery Holder. If you don't have access to a Volt meter to determine the diagnosis of the battery, then assume that it requires replacement, where a replacement would be any brand of battery that suits the BR1225 specs: 3 volts approx 40maH 12mm diameter 2.5mm thickness no wires and no connector. HP refers to call the cmos battery by the name of RTC Disk Cell. To order from HP refer to HP Spare Parts Number 241439-001 (Miscellaneous Plastics Kit Component) Applicable to Compaq Evo Motherboards: 291581-001 (Evo N610c) and 319778-001 (Evo N620c)
d0e4_2.jpgNow, while replacements can be for just any electronic store near your home/business, pharmacies also carry these types of batteries, but if your choice is to buy them here on ebay, we recommend buying them from a seller who has other Evo Part integration and has proven themselves to be fully knowledgeable on HP/Compaq Evo Models, whereby most likely they will stock other parts you will need for your Evo such as Hard drives, LCD inverters, LCD display, optical drives, memory and maintenance care products. Below are two sellers and the ebay store links to their Cmos Disk Cells. We have no affliation with them, but as buyers we have purchased from both of them in the past with good success and can recommend them.
good luck
gorbesia
Aug 02, 2011 | HP Compaq Evo n610c Notebook
Compac Evo N610c - 2Mhz - 1 GB ram - Windows XP SP2 Blinking charging light went out and computer won't start up again. Checked power suplly (18,57v dc) Replaced with another power supply, replaced the...
Your computer has an open circuit on the system board. If you have data on the machine you can remove the hard drive and connect it to a PC, Sorry I can't think of a more elegant solution. I hope I'm wrong.
Mar 11, 2011 | HP Compaq Evo n610c Notebook
The battery is fully charged and loses the charge within 15 minutes of being fully charged. Battery is 18 months old!!!!! Help
Simple fix turn on the puter on the logo screen press F10 to go into bios setup page scroll over to battery calibration on the tabs on top you will see HDD and Battery choose battery.
Now hit calibrate.
1- Recharge
2- Discharge
2- Recharge
Let the puter complete all of the sessions without interruptions.
That will calibrate your battery to charge correctly. thanks.
Nov 07, 2010 | HP Compaq Evo n610c Notebook
My compaq evo n610c switches itself on when the
Disconnect the power cable from the Notebook and then remove the Battery pack. While the Battery pack is removed, press and hold the power button on the Notebook for 15 seconds.
Next, reinsert the Battery pack and connect the power cord to the Notebook and turn it ON. While the Computer is booting, you can view the information on the bottom of the screen to get to the Setup Screen.
On the Setup screen, use the right arrow key to highlight the "Exit" menu, then select the option "load/get default" and press the Enter key followed by F10 keypress to reset the BIOS and save and exit the screen.
Feb 26, 2010 | Compaq Evo N610C Notebook
Screen turn off of Compaq Evo Notebook N610c
check your settings under power options in control panel, also check advanced power options in bios. very likley you will find problem here.
Jul 25, 2009 | Compaq Evo Notebook N610c
Compaq Evo N610C Faint Screen
Usually it's the inverter. Sometimes it's the backlight / lcd, and occasionally it's the lcd cable and or video card.
Easiest thing to do is order a replacement inverter from ebay. They're cheap and then swap it. You just need to remove the outside lcd bezel, it's just four or five screws and you're in business.
Feb 22, 2009 | Compaq Evo N610C Notebook
Laptop Compaq N610C did not powered ON
Remove your battery - start the unit on A/C then after booting up refitted battery.
Jan 21, 2009 | Compaq Evo N610C Notebook
Battery installer
My compaq evo n610c have the following problem: "103 circuit charge failure" and use power AC only.
best regards
Sep 19, 2008 | Compaq Evo N610C Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Compaq Evo N610C Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
