Question about Maytag Portable Air Conditioner M6P09S2A
Water spillage in Dimplex portable air conditioner
We bought a Dimplex DAC 12005 portable air conditioner last summer. It was floor stock and the salesperson promised to send us the instruction manual, but never did! Do you know where I can get one, or if not, can you help out with this specific question?
We're not sure whether the drainage hole at the bottom should be plugged up or not when in use. There is a container to catch the water and a pipe that comes with it, so we've been using this to 'catch' the water when the unit is in use, however we're finding that the water is just spilling out under the unit.
Any help would be greatly appreciated.
Cheers
Leanne Linmore
Weetangera ACT Australia
Hi Leanne,Bung stays in and you dont take it out until the red light (4th on right on top of unit) comes on, then you empty it taking bung out and use tube to get the water out. It will probably take some time (days of continuous operation) for the light to come on, depending on your humidity etc. For easy emptying, wheel the unit to a bathroom or outside where if it spills a bit it won't matter.
Ours is working okay although it just stopped blowing cold air and is only blowing room temp air. we have guests tonight and its hot! I came here looking for a solution to my prob and found yours!
chhers, Les.
Posted on Jan 08, 2008
  • squatter Jan 08, 2008
    Leanne,
    I found the manual. It needs water to go over its condenser to work. Generally, it gets it internally by dehumidifying the air in the room. That's why you need to leave the bung in. It has a 800ml tank and it will need emptying when this is full (that is, it makes more water then it needs in a humid environment and the light comes on red when its full - how long depends on your environment.) The opposite can happen (as it did here tonight) and the humidity was so low that it couldn't make enough water and it just blew room temp. air. This was fixed by pulling out the little draw above the bung at the back and adding about 400ml of water to get it going. it's going like a champion again now! Hope this helped.
    Les.
  • 833 Answers
Generally, air conditioners should operate in a way that causes them to use the condensed liquid as a condenser coil coolant and then reject it outside. The problem is that if the unit is inside the area you're cooling...you're going to recycle that water back into the very same air you took it out of. So...if the unit exhausts air outside, plug the hole. If not, then don't. Watch for flooding! Put the unit in a tray, if possible.
Get hold of these folks: http://www.dimplex-australia.com/DIMPLEX/jsp/c_contact.jsp
Funny, here in New York, we had a dusting of snow today!
Posted on Jan 02, 2008
I need a drain hose for a DAC-12005 Dimplex portable air conditioner as soon as possible thank you.
Google make and model and look for parts list and stockist's Fix ya does not do parts
Jan 08, 2018 | Dimplex Heating & Cooling
How can I obtain a instruction manual for Dimplex DAC-12005?
try www.dimplex.de/en/downloads/installation-instructions.html
Dec 11, 2014 | Dimplex Heating & Cooling
I bought a Duacraft Mobile Air Conditioner 8000 last summer, today I came home to find the floor soaking wet, no warning light came on, I can't locate where particularly on the unit the water us coming...
inside the air conditioner there should be a tray for catching condensation fro the coil. it should be full of water. the water warning light on your model is at the top left on the temperature panel watch for it as this has happened to me several times as well.
Jun 15, 2011 | Heating & Cooling
Dimplex DAC 12005. A C What is the power usage How many Kw per hour is it using
12000 BTU = 3.5 kilowatts per hour. For comparison, this is roughly equivalent to two toasters.
Charlie
Feb 05, 2011 | Heating & Cooling
What is the reason for putting water in the slide opening on the back of a dac 12005
This question is about as bad as the others seen today.
If there is any water available to spray on the outside condenser of an air conditioner it can improve the cooling, i don't know **** from from Dac but if there is a water suppy that helps leak over the coil of the outside condenser then it's a ++.
Btu of Dimplex Dac 3400/Toyotomi TID-1200 please
It is a 3400BTU unit--Checked from my own unit.
Cheers,
Tony
Sep 09, 2010 | Toyotomi TID-1200 Air Conditioner
Water leak with the dimplex dac12ac
Hi there seems to be a water outlet at thtop rear of the unit where you need to drain water from its a little" rubber plug" hope this helps good luck
Dec 07, 2008 | Heating & Cooling
Instruction Manual
I had the same problem. If you are in Australia, the Dimplex Customer Service number is 1300 6739 033. I phoned and they are mailing me the instructions. Maybe don't say you bought the machine at a garage sale.
If you are not in Australia, try the way I did to get your local customer service number - Google the product number and go to the Dimplex website, and there should be a "Contact Us' button with a phone number or mailing address.
Pat
Jun 21, 2008 | Heating & Cooling
Heating & Cooling Logo
1,842 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
