Question about Power Color RADEON X1550, (256 MB) Graphic Card
Black screen I just had my x1550 installed along with a new powersource (400) to give it what it needed. Upon playing COD4 it kept doing a self-test check on itself and I could not figure out why. It would happen randomly as in every 10-45mins. of play. This is the only game it would happen to and now it won't even show anything, just a black screen but yet I have sound. I now have to use my old PCI factory card to even use my pc and cannot play the games on it. Any suggestions?
    President:
  • 2,351 Answers
I have three suggestion. Since your currently using your old video card now I'd like you to update windows. You need to have at least .Net framework 2.0 installed in your PC. Do not skip installtion of earler version of .Net framework like 1.0, 1.1.
If you haven't updated in a while this may take some time.
Download & install DirectX 9.c at this link: http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
Download your latest drivers from PowerColor here: http://www.powercolor.com/eng/support_driver.asp?CategoryID=1&SeriesID=2&ModelID=7
Restart the PC. After windows finishes loading remove your older video software from Control Panel -Add/Remove. Shut down PC, unplug power cord. Remove older video card, clean slot with a blast of canned air or clean paint brush. Install newer card. Make sure it is seated correctly. Re-connect Pc & boot to windows. Install downloaded drivers. If your card continues to wig-out after 10-45 min, it might be over heating. Make sure you have plenty of fresh air to enter the case.
Posted on Jan 01, 2008
How to get the Power Color RADEON X1550, (256 MB) Graphic Card to rotate screen number 2 to vertical rotation? There is not setting on the monitor itself and the plug n play does not give me the option to...
An upside down image - this is caused by unintentional pressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key. Some computers do not have this function.
Sep 24, 2012 | Power Color RADEON X1550, (256 MB)...
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Getting printer stall code on screen...
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
To self-test the printer, please follow the steps given below:
1. Press and hold the "Plus" (+) button. While holding it down, press the "Scan" button. Once the screen changes, release both buttons. The screen will display the firmware version until the buttons are released. Then it will display 0: Button test.
2. Press the "Plus" (+) button once. The screen will display "Single Test Page."
3. Press the "Menu" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed.  If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 03, 2009 | Lexmark X5250 All-In-One InkJet Printer
Carrier stall
1. Press the "Menu" button 10 times. It should then read "Maintenance" on the printer's display screen.
2. Press the "Select" button once. You should then see "Cartridges" displayed on the printer screen.
3. Press the "Right Arrow" button 3 times, which then brings you to the "Self-Test" option.
4. Press the "Select" button once. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues and we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Oct 03, 2009 | Lexmark X85 All-In-One InkJet Printer
I have same problem
Download the latest AGP drivers for your motherboard. and install
Aug 04, 2009 | Sapphire RADEON X1550 Graphic Card
My new xbox just got it for christmas is freezing
Right, lay your Xbox360 down dont keep it upright, try installing COD4 to your hard drive then once installed go into you game library and click on cod4 and click play from hard drive ( and if you dont know how to install games to the hard drive make sure your xbox isnt on automatic start when a disc is inserted and put the disc in and when it says play cod4 press Y and then click install to hard drive) hope this helped....
Feb 07, 2009 | Microsoft Xbox 360 Console
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Why do some DVDs play well and others don't?
just check the data transfer wires.may ur probles sloved
Mar 06, 2007 | Power Acoustik PADVD-150 Car DVD Player
Power Color RADEON  X1550, (256 MB) Graphic Card Logo
308 people viewed this question
Top Power Color Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Power Color Computer and Internet Expert? Answer questions, earn points and help others
