Question about JVC GR-D33 MiniDV Digital Camcorder
Lens cap problem
When i turn on the camera, it reflects sound 12bit and lens cap. when i try to play anything from tape nothing will play. the tape cannot move. when i press rec. it will show me that its recording as minutes left on the tape will be showing reducing. nothing displays on the lcd
  • Detrick105 Jan 03, 2008
    I have the same problem only I can view previously recorded things on the tapes, but when I try to record something, the sound gets recorded, but nothing shows up on the lcd. I also can't see anything through the viewfinder.
    Problem Solver:
  • 10 Answers
I ma sure wht u talking about !!
Posted on Jan 01, 2008
My problem is im trying to record and i have the camera switched to tape and have it turned on to camera and it records sound but will not record picture, but will play back other tapes on the screen ok.I...
If the iris is opening to let light in, that light is not being changed to a picture signal or that picture signal is not
going into the camera circuits, What you see in the viewfinder is what is being recorded, Make sure that no cables have been left plugged in to the camera and turn the power on and off several times, I have seen the iris stick when cameras were not used for a while. The iris is inside or behind the lens and closes completely when you turn the camera off, If it is stuck, SOMETIMES it will open with repeated tries of turning it off and on or even removing the battery and putting it back in. And maybe it is just the vibration of opening and closing the battery compartment door or the slight vibrations of pushing the power button repeatedly. If it sticks once, it will stick again. This is not a repair, just a way to get those one time pictures' before.
Jan 08, 2018 | Canon ZR50MC Mini DV Digital Camcorder
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
Cant see images through camera
Try removing the lens cap, sometimes it's just that easy. Be sure you have fresh DV tape in camera, and the setting is set to camera/tape.
Mar 22, 2009 | Sony Handycam DCR-HC36 Mini DV Digital...
Camcorder says lens cap is on when its not
This is problem of bad CCD Imager in your JVC GR-D32U model. This part need to be replaced.
JVC offers Free of Cost repair for such problem in same model cameras.
Click JVC CCD Program for details.
Nov 09, 2008 | Cameras
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Jun 18, 2008 | Video Cameras
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
JVC DIGITAL VIDEO CAMERA GR-D23EK
i have exactly the same problem. when i try to use the camera i get blank screen. i have try to reset but nothing.
Dec 08, 2007 | Cameras
Horizontal lines on playback screen
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Does not record video
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Oct 02, 2007 | Sony Handycam CCD-TRV608 Camcorder
JVC GR-D33 MiniDV Digital Camcorder Logo
105 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
