Question about Epson LX-300 Matrix Printer
Processor sir, i wanna know that what is difference between amd & pentium processor ? in comparison with each other which one is good ? which one has a good speed? also sir pls tell me what is printer head ? waiting for ur reply.
  • h_s_shah Feb 04, 2008
    where is printer head located?
  • Epson Master
  • 1,879 Answers
Pentium is made by INTEL
AMD makes athlon
both companies make fast & good processors, depends on your need
the printer head is the "thing that moves back and forth sideways" that puts ink on the paper
Posted on Jan 22, 2008
  • monk3ybidzness
    monk3ybidzness Feb 05, 2008
    it is located right under where the ink cartridges are (EPSON for example) or sometimes it is part of the cartridge itself (HP for example).
Aopen ux915g
Yes. Any Intel Pentium 4 processor will fit fine. That said A P4 processor is fast, but the Pentium D is much faster. The D stands for Dual Core. This means that they have two on die processor cores instead of just one, as the Pentium 4 does. Two processors also makes it better for "demanding" applications.
The Pentium D is better if you have a motherboard that will utilize the technology. As stated the Pentium D is Duel core. This is Intel's way of creating the closest environment of a true duel processor. The HT is for Hyper-Threading which acts like a zipper and allows several applications to process at the same time. The Pentium D will really make a difference when used with the new 64 bit operating system.
However, HT (Hyper-threading) P4, does have emulated Dual Core processing. In short, the processor makes the computer think its runing a dual core. The Pentium 4 also has a couple different levels, so if you are trying to make a comparison, make sure that you look carefully.
Although neither can match the power of an Athalon or an AMD x2 processor. If you are buying, get something with 64 bit processing. WAY faster and better for games and high graphic systems.
May 13, 2014 | Computers & Internet
Hi sir/mam, i have a gigabyte motherboard 7vm333m-rz n now i m presently in tis board AMD processor is running... can i change the processor by pentium 3 instead of AMD.
-> NO
It has a Socket 462 processor socket. (Also known as Socket A,
http://en.wikipedia.org/wiki/Socket_A )
This is strictly for AMD processors ONLY, and only for AMD processors that use this processor socket.
An Intel Pentium III processor, that is not a Slot 1 processor, uses a Socket 370,
http://en.wikipedia.org/wiki/Socket_370
List of Intel Pentium III Microprocessors,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_III_microprocessors#.22Coppermine.22_.28180_nm.29
Scroll down also.
{ If it states Slot 1 AND Socket 370, it means there are processors Intel made, that were that model, but could have been a Slot 1 processor, or Socket 370 processor.
Using the first example;
Pentium III 500E,
http://www.cpu-world.com/CPUs/Pentium-III/index.html
The first example on top, is an Intel Slot 1 processor style.
The rest of them on down are Socket 370 processors, EXCEPT for the Pentium III Xeon. (Zee-On)
It is a Slot 1 processor.
http://en.wikipedia.org/wiki/Slot_1
Want to learn more about computer technology? Post back in a Comment, and I will give you some links.
Regards,
joecoolvette
Jul 21, 2012 | Computers & Internet
Can i put a amd processors in a dell dimension
Short answer: NO.
Long answer: AMD processors have a different pin-arrangement than found on a Socket 478 motherboard, so they physically will not fit.
Jul 03, 2010 | Dell Dimension 4550 P4 Socket 478B...
Hi i need more help in knowing just what type of processor chip to buy i know i need to put the same type back in my problem is i dont know what type it is my pc is acer aspire t135 1.8ghz it says on my...
Hi Paul,
Correct, you have to use the same type, but you can upgrade to a faster CPU.
According to the specs for your computer it can take the following:
AMD Sempron processor 2600+ to 3300+, 333MHz FSB
AMD Athlon processor 2800+ to 3200+, 400MHz FSB
See:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT135/AspireT135sp2.shtml
The Athlon's are better...faster Bus. The Sempron is cheaper.
The 2 processors you describe are very similar. The difference between the 2 is that the first one is capable of running 64-bit operating systems and applications. The second one is strictly for 32-bit systems.
The next question will probably be, "What do I have?" Probably a 32-bit system. You can go with the 64-bit CPU and be safe as it can run both. You can see what your old one is by the revision number on the top of the CPU. You can use the following comparison chart to see the differences:
Sempron 3100+ Comparison
I hope this has been some help. Maybe it has just caused more questions. Just ask.
Thanks for using Fixya.
Mar 24, 2010 | Computers & Internet
GD8 motherboard
The GD8 mobo spec says that the bopard is only compatible with P4 and Celeron D processors so no you cant swap it! Generally the Athlon 1800+ is a better processor but it depends on the mobo, BIOS, RAM setup etc.
Sep 09, 2009 | Abit GD8 Motherboard
Want to have a clear comparison between AMD Athlon Bribane X64 5200+ 2.7 GHz with Intel E4500 Core2Duo 2.2 GHz
Hi there.
There's not much difference between the two processors.
The AMD has a slightly higher clock speed and is a very stable processor.
The Intel processor are known to run hot so cooling is an issue, but overall Intel are leading the way with dual core processors at the moment.
Have a look at the AMD Phenom 2 processor as they are apparently very good.
Good luck and thanks for using FixYa!!
Mar 17, 2009 | Computers & Internet
I got an AMD turion x2 64 processor in my new notebook n after reading reviews comparison to core 2 duo i m really tensed!
You made a good choice. In the CPU arena right now, the difference between the two CPUs is a toss up. The slight advantages of one vs. the other in benchmark tests is nominal and actually artificial..
What happens with an AMD CPU is with the associated GPU onboard. And with a 64bit processor, the number of apps and games that take advantage of 64bit CPUs has always been limited but they are growing. This will only become more and more numerous.
The main architectural difference in the two was in how the two cpus communicated and the AMD was first to use a bus between the two cores and the Intel had to go to the onboard memory controller and back. That was in the first inception. Still, AMD has been far in advance of Intel and Intel has played catch up in tricks inside the cores and how the north and southbridge took advantage of the cores' architecture.
Needless to say, I'm an AMD power user and my gaming rig has an AMD dual core on an Asus/Nvidia board and an Nvidia PCIe 9800 GPU.
In the long run, all modern notebooks require you to own a pad cooler to use these in your lap or not, they all produce heat. So, just get a good one designed for your laptop so it snaps into place and will keep your rig nice and cool.
At a LAN Party you won't suffer from having a dual core AMD cpu, you'll hold your own and it will be an even playing field and the wins will go to the person with the fastest fingers... as it should be.
Sleep easy friend,
Worldvet
Oct 26, 2008 | HP Pavilion DV5234US Notebook Laptop
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
Difference b/w Core to duo and daul core
Core 2 Duo is a Brand name by intel to identify his class of Dual core CPU
a Dual core CPU is basically two CPU in one package, which dramatically improves performance over previous architectures.
Pentium Dual Core is another brand name by Intel to identify his new entry level CPU offer.Basically Pentium dual-core are similar to Core 2 Duos except they(pentiums) are slower and cheaper.
they both are dual core CPUs.
I would prefer a core 2 Duo having to choose a laptop because of better performance, but the prize is different for the two solutions.
Jun 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Mother board CD lost
Here is a link to your drivers!
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=256
Jun 21, 2008 | AMD Athlon 64 3500+, 2.2GHz...
Epson LX-300 Matrix Printer Logo
35 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
